Hello, dear developer!
I'm using you test program and found an exception in procedure:
TGXProgram.ReadScalerAndUnits
During debugging, I noticed that FreeAndNil(list) instruction is called when list=nil
This corrupts the data in the variable tmp, so the code below is executing with an exception
My opinion is to move FreeAndNil(list) after
if list.Count <> 0 Then
ReadList(list);
where list variable is not nil
Hi, Thank you for this…
Thank you for this information and for reporting it. Your idea is good and it's added for the client example during next week.
