By tukur, 31 May, 2023 Forums Gurux.DLMS.AMI Hello, I'm getting this error when I try to run a docker container after I updated to the latest docker image Image Hi, Please, don't add pics… Hi, Please, don't add pics. Plain text is better to read. Your MySQL server is not available. Check the host name. BR, Mikko Hi @Kurumi, MySql server is… Hi @Kurumi, MySql server is up and running. I created a new user with all privileges, Yet I can't access the app. I'm using docker Hi, This is a clear MySQL… Hi, This is a clear MySQL connection error. I try with empty MySQL and get the latest docker. It starts to work without problems. Try to install MySQL client for the docker. Open docker using the terminal and run this. apt-get update && apt-get install -y default-mysql-client Then try to connect to your MySQL DB. mysql -h YOUR_HOST_NAME -u USER_NAME -p I believe that you get the same error message. Check also the firewall. BR, Mikko Log in or register to post comments
Hi @Kurumi,
