Change type failed. Not enought data
6 posts / 0 new
Last post
salman1538
Hi All, I try to read date and time from Meter.
1.1.0.9.1.255:2 -> I get the time
1.1.0.9.2.255:2 -> I get the message change type failed. Not enought data
I am using Gurux DLMS Client Example in Python.
Please guide to resolve the error.
Kurumi's picture
Can you add a trace from the bytes so I can check it?
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
salman1538
Hi, thanks for reply. Below is the trace from log file -t Verbose
[Trace removed]
Salman1538
Kurumi's picture
I was able to repeat this. I create an issue from this and a new version is released later today.
https://www.gurux.fi/node/18287
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
salman1538
Thanks for quick support. Got the new version 1.0.103 - Will update after test.
Salman1538
salman1538
I test and it works fine. Thank you.
Salman1538
