I can't compile the Atmel Client code
27 posts / 0 new
Last post
poojash
I am working on implementing the Gurux. c on my meter.. I tried compiling the "GuruxDLMSClientExample" on Microchip studio with gcc compiler but is giving me errors (I have attached Jpg file of errors)
Please how can I include the missing header file?
Kurumi's picture
I believe that the best solution is if you create a new project for your compiler and then simply copy main.c- file and DLMS development folder for your project.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
poojash
Could you please give me configuration details like which UART ,clock or which peripherals i want to use it for.
pooja
Kurumi's picture
Those settings depend on your HW and what need to build.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
poojash
I created a new project for gcc compiler and then copied main.c- file and DLMS development folder for my project. but still there are errors see on png attached.
Image:
pooja
Kurumi's picture
Your compiler is not supporting IPv6. Open gxignore.h and un-comment DLMS_IGNORE_IP6_SETUP.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
poojash
Yes I already uncommented DLMS_IGNORE_IP6_SETUP but still it gives these errors. whether I want to add these arpa/inet.h? and Where I have to add this?
pooja
Kurumi's picture
Get the latest version. Include order is changed. What gcc version you are using? Can you run command below and add version information here.
gcc --version
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
poojash
I am using gcc version:6.3.0
pooja
poojash
are these dlms files only compatible with gcc compiler?
pooja
Kurumi's picture
You can use any compiler you want to. I just wanted to know the compiler version so this can be checked with the same compiler. Your compiler is used in internal tests. Can you compile the project now?
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
poojash
No.. Not yet... please tell how I can compile this project
pooja
poojash
Hello sir
I compiled by using updated development files but there are some errors.
I compiled step by step main.c then I recognize that when I comment "ret = com_read(&con, &clock.base, 2);" this function then code compiles but when I uncomment it shows me errors:
Image:
pooja
Kurumi's picture
Un-comment the DLMS_IGNORE_SERVER.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
poojash
Hello
Thank you.... Compiled successfully.
pooja
poojash
hello sir
Code is compiled successfully but not working.
I have used usart0 and your main.c is copied as it is and make changes in cl_Init according to our design. but meter is not goes in HDLC mode.
pooja
Kurumi's picture
If the meter is not answering your messages check your serial port settings.
If you are using optical it might be that you need to send IEC initialization command first.
Try to connect first with GXDLMSDirector and check the correct settings.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
poojash
We are not using Optical we are using Rj9 and Uart for communiction with Max232 IC between then it works good when arduino is used but when SAM board used it not working
pooja
Kurumi's picture
I believe that it's in UART. Start DLMS server using the serial port in the PC.
https://github.com/Gurux/Gurux.DLMS.Net/tree/master/Gurux.DLMS.Server.Ex...
Then connect your reader to a PC. In that way, you can easily see send and received bytes in the command prompt.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
poojash
Hello
Board is Connected to meter following is Tx and Rx signal got from meter.
TX: 7E A0 07 03 41 93 5A 64 7E
RX: 7E A0 1E 41 03 73 8E 7F 81 80 12 05 01 80 06 01 80 07 04
00 00 00 01 08 04 00 00 00 01 53 3B 7E
Thanks for the help and quick reply.
pooja
Kurumi's picture
The data is correct. Can you see what is the actual data in the buffer before you parse it?
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
poojash
How i can check it
pooja
Kurumi's picture
If you don't have Atmel-ICE debugger you can print the content of the buffer to the serial port.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
poojash
I want to know the Clock configuration Required to communicate using UART to meter.
pooja
Kurumi's picture
You can use GXDLMSClock object to read or write the clock of the meter.¨
http://www.gurux.fi/Gurux.DLMS.Objects.GXDLMSClock
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
poojash
hi,
I am not able to communicate with meter so I want to know it is essential to configure UART Clock. I am Using SAME54 Board. cl_Init() is also not executing.
pooja
Kurumi's picture
You need to call cl_Init in your call to initialize the correct DLMS settings. If your UART timing is different than the meter, meter doesn't reply.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
