I have some following queries regarding CSR (Certificate signing request)
1. While importing the certificate (using import certificate method) , which public key is used to verify the received certificate signature ?
a. Public key of the ROOT CA which has signed this received certificate.
b. Public key which is received with the certificate.
2. While importing the certificate (using import certificate method) , which data used to calculate the SHA-256 which is then used to verify the signature of the certifiacet?
1 ROOT CA signs the certificate and the signature must match with the certificate data.
2. The signature is counted from the content of the certificate.
3. The normal action reply is returned. There is no data.
Hi Aoudumbar Pawar,
Hi Aoudumbar Pawar,
