I want to change capture objects into the Load Profile channel 1.1.99.1.0.255 in a meter.
In the meter document it says "Load Profile logger, Attr1 = 1.1.99.1.0.255, Attr 2-3 Access Read, Attr 4 Access ReadWrite, Attr 5-8 Access Read.
So in the light of this, I believe that I can write capture objects with Attr Index 4.
However,
var profileGeneric = new GXDLMSProfileGeneric("1.1.99.1.0.255");
var captureObject = new GXDLMSCaptureObject(4, 0);
profileGeneric.CaptureObjects.Add(new GXKeyValuePair<GXDLMSObject, GXDLMSCaptureObject>(new GXDLMSRegister("1.1.1.8.0.255"), captureObject));
var reply = new GXReplyData();
DlmsReader.ReadDataBlock(dlmsClient.Write(profileGeneric, 3), reply);
There are only three attributes in the register-object and you have set attribute #4. Check that.
