In new version of the Gurux client under the association object update low association action available.
It means to change low association password change(MR-association)thorough US association? or else what is the functionality of this feature?
if yes, How we can change/update low_password?
please help me what is the purpose of this feature?
You usually update the password for the connected association.
But yes, Indian meters allow updating low-level (MR) password when connected with High authentication (US). This is added for the Indian meters.
If you want to use this return ReadWrite access for the secret (attribute #7) in getAssociationAttributeAccess-method.
As you said that, I updated low -level password in Post_write function in the exampleserver.c file but when I am changing the low association password it is effecting high association instead of low association.
if meter switched off it working fine. but in real-time scenario meter switch off is not required na?
please help me where is the problem?
When ever I try to update/change the MR Association password it is effecting US Association password instead of MR Association password.
please help me where i did mistake? how to resolve this issue?
//If client try to update low level password when high level authentication is established.
//This is possible in Indian standard.
if (e->target == BASE(associationHigh) && e->index == 7)
ret = cosem_getOctetString(e->value.byteArr, &associationLow.secret);
saveSettings();
e->handled = 1;
You must also update the low-level password on the server-side in post_write.
It's updated for the US association.
Any update on this issue?
Hi Ashok,
Hi Ashok,
We are releasing the new version from the server example at the end of next week where this example is added.
Add this to preWrite. It will handle it.
saveSettings();
e->handled = 1;
Thank you for reply ,
It is Working fine.
Thanks for the information. This is added to the future example server.
