Unable to fetch values of scalar profile from DCU (Data Concentrator Unit) using my sample client app.
1 post / 0 new
pradson
I am able to fetch values of scalars profile from DCU (Data Concentrator Unit) using DLMSDirecotor tool.
But unable to fetch values using my sample client application. I am using Gurux.DLMS.CPP for my sample client application. I am sharing to you my sample code and logs GXDLMSDirector tool for the same.
Kindly check and suggest me.
########### Sample Code to read scalars values of instantaneous profile ############
std::locale::global(std::locale(""));
CGXDLMSSecureClient *m_DLMSclient = NULL;
m_DLMSclient = new CGXDLMSSecureClient(true, 32, 19, DLMS_AUTHENTICATION_LOW, "sss01", DLMS_INTERFACE_TYPE_WRAPPER);
m_DLMSclient->SetUseUtc2NormalTime(true);
CGXCommunication *m_pCGXCommunication = NULL;
m_pCGXCommunication = new CGXCommunication(m_DLMSclient, 5000, GX_TRACE_LEVEL_INFO, NULL);
if ((ret = m_pCGXCommunication->Connect("192.168.0.10", 4061)) != 0) {
printf("Couldn't connect to the device... %s.\r\n", CGXDLMSConverter::GetErrorMessage(ret));
if ((ret = m_pCGXCommunication->InitializeConnection()) != 0) {
printf("Connection initialization failed %s.\r\n", CGXDLMSConverter::GetErrorMessage(ret));
m_pCGXCommunication->Close();
m_pCGXCommunication->Release();
return 0;
int iRet = 0;
CGXDLMSProfileGeneric objT("1.0.94.91.3.255"); // Instantaneous-Profile object...
string sCapObjsT("");
///////////// Able to read captures objects //////////////////////////
if ((iRet = m_pCGXCommunication->Read(&objT, 3, sCapObjsT)) != 0) {
return false;
///////////// Unable to read values read method returns 258 error number. //////////////////////////
string sUnitsScalarsT;
if ((iRet = m_pCGXCommunication->Read(&objT, 2, sUnitsScalarsT)) != 0) {
return false; //
return 0;
########### Logs of GXDLMSDirector tool to read scalars of all profile objects ############
GXDLMSDirector 8.2.2101.2901
Log created 13:11:50
13:12:36 Initializing Network connection.
13:12:37 Send AARQ request.
00 01 00 20 00 13 00 35 60 33 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 07 80 05 73 73 73 30 31 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF
13:12:43 Release request
00 01 00 20 00 13 00 05 62 03 80 01 00
13:12:43
00 01 00 13 00 20 00 02 63 00
13:12:52 Data send failed. Try to resend 1/3
13:13:07 Data send failed. Try to resend 2/3
13:13:22 Failed to receive reply from the device in given time.
at GXDLMSDirector.GXDLMSCommunicator.ReadDataBlock(Byte[] data, String text, Int32 multiplier, Int32 tryCount, GXReplyData reply)
at GXDLMSDirector.GXDLMSCommunicator.ReadDataBlock(Byte[] data, String text, Int32 multiplier, GXReplyData reply)
at GXDLMSDirector.GXDLMSCommunicator.ReadDataBlock(Byte[] data, String text, GXReplyData reply)
at GXDLMSDirector.GXDLMSCommunicator.ReadDataBlock(Byte[][] data, String text, GXReplyData reply)
13:13:28 Initializing Network connection.
13:13:28 Send AARQ request.
13:13:28
00 01 00 13 00 20 00 2A 61 28 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 0F 04 0D 08 00 06 5F 04 00 00 10 1D 20 00 00 07
13:13:28 Parsing AARE reply succeeded.
13:13:30 --- Collecting objects. ---
13:13:30 Collecting objects
00 01 00 20 00 13 00 0D C0 01 C1 00 0F 00 00 28 00 00 FF 02 00
13:13:32
00 01 00 13 00 20 06 24 C4 01 C1 00 01 13 02 04 12 00 08 11 00 09 06 00 00 01 00 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 02 03 0F 09 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 08 04 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 07 11 01 09 06 01 00 5E 5B 00 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 03 00 02 02 0F 02 03 00 02 04 12 00 07 11 01 09 06 01 00 63 01 00 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 03 00 02 02 0F 02 03 00 02 04 12 00 07 11 01 09 06 01 00 63 02 00 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 03 00 02 02 0F 02 03 00 02 04 12 00 07 11 01 09 06 00 00 63 62 00 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 03 00 02 02 0F 02 03 00 02 04 12 00 07 11 01 09 06 00 00 63 62 01 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 03 00 02 02 0F 02 03 00 02 04 12 00 07 11 01 09 06 00 00 63 62 02 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 03 00 02 02 0F 02 03 00 02 04 12 00 07 11 01 09 06 00 00 63 62 03 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 03 00 02 02 0F 02 03 00 02 04 12 00 07 11 01 09 06 00 00 5E 5B 0A FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 03 00 02 02 0F 02 03 00 02 04 12 00 07 11 01 09 06 01 00 5E 5B 03 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 03 00 02 02 0F 02 03 00 02 04 12 00 07 11 01 09 06 01 00 5E 5B 04 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 03 00 02 02 0F 02 03 00 02 04 12 00 07 11 01 09 06 01 00 5E 5B 05 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 03 00 02 02 0F 02 03 00 02 04 12 00 07 11 01 09 06 01 00 5E 5B 07 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 03 00 02 02 0F 02 03 00 02 04 12 00 07 11 01 09 06 01 00 5E 5B 07 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 03 00 02 02 0F 02 03 00 02 04 12 00 07 11 01 09 06 01 00 5E 5B 07 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 03 00 02 02 0F 02 03 00 02 04 12 00 07 11 01 09 06 01 00 5E 5B 07 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 03 00 02 02 0F 02 03 00 02 04 12 00 0F 11 00 09 06 00 00 28 00 00 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 00
13:13:32 --- Collecting 19 objects. ---
13:13:32 --- Created 19 objects. ---
13:13:32 --- Reading scalers and units. ---
13:13:32 --- Reading scalers and units end. ---
13:13:32 Reading object 1.0.94.91.0.255, interface ProfileGeneric
00 01 00 20 00 13 00 0D C0 01 C1 00 07 01 00 5E 5B 00 FF 03 00
13:13:32 Get profile generic columns...
13:13:33
00 01 00 13 00 20 05 82 C4 01 C1 00 01 4E 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 1F 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 33 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 47 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 20 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 34 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 48 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 21 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 35 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 49 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 0D 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 0E 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 09 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 03 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 02 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 09 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 0A 08 00 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00 60 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 00 00 5E 5B 08 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00 5E 5B 00 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00 00 01 00 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00 60 02 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 00 00 00 01 02 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 24 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 38 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 4C 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 07 26 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 07 27 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 07 28 FF 0F 02 12 00 00 02 04 12 00 01 09 06 01 00 80 07 29 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 07 35 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 07 36 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 07 37 FF 0F 02 12 00 00 02 04 12 00 01 09 06 01 00 80 07 2D FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 07 23 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 07 24 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 07 25 FF 0F 02 12 00 00 02 04 12 00 01 09 06 01 00 80 07 2E FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 08 1C FF 0F 02 12 00 00 02 04 12 00 01 09 06 01 00 80 07 2B FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 08 1D FF 0F 02 12 00 00 02 04 12 00 01 09 06 01 00 80 07 2C FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 08 22 FF 0F 02 12 00 00 02 04 12 00 01 09 06 01 00 80 07 31 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 07 44 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 07 41 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 07 42 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 07 43 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 07 48 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 07 45 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 07 46 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 07 47 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 07 11 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 07 15 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 07 12 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 07 16 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 07 13 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 07 17 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 05 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 06 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 07 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 08 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 10 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 07 95 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 08 07 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 08 08 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 08 09 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 08 0A FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 08 0B FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 08 0C FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 08 0D FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 08 0E FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 08 BE FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 08 BF FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 08 C0 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 08 C1 FF 0F 02 12 00 00
13:13:33 Reading object 1.0.99.1.0.255, interface ProfileGeneric
00 01 00 20 00 13 00 0D C0 01 C1 00 07 01 00 63 01 00 FF 03 00
13:13:33 Get profile generic columns...
13:13:33
00 01 00 13 00 20 01 38 C4 01 C1 00 01 11 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 0E 1B 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 20 1B 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 34 1B 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 48 1B 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 1D 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 10 1D 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 02 1D 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 05 1D 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 06 1D 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 07 1D 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 08 1D 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 07 0E FF 0F 02 12 00 00 02 04 12 00 01 09 06 01 00 80 07 59 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 07 6E FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 09 1D 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 0A 1D 00 FF 0F 02 12 00 00
13:13:33 Reading object 1.0.99.2.0.255, interface ProfileGeneric
00 01 00 20 00 13 00 0D C0 01 C1 00 07 01 00 63 02 00 FF 03 00
13:13:34
00 01 00 13 00 20 00 F0 C4 01 C1 00 01 0D 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 02 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 09 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 0A 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 5E 5B 01 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 5E 5B 02 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 05 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 06 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 07 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 08 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 10 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 07 95 FF 0F 02 12 00 00
13:13:34 Reading object 0.0.99.98.0.255, interface ProfileGeneric
00 01 00 20 00 13 00 0D C0 01 C1 00 07 00 00 63 62 00 FF 03 00
13:13:34 Get profile generic columns...
13:13:34
00 01 00 13 00 20 00 F0 C4 01 C1 00 01 0D 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00 60 0B 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 1F 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 33 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 47 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 20 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 34 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 48 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 21 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 35 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 49 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 02 08 00 FF 0F 02 12 00 00
13:13:34 Reading object 0.0.99.98.1.255, interface ProfileGeneric
00 01 00 20 00 13 00 0D C0 01 C1 00 07 00 00 63 62 01 FF 03 00
13:13:34
00 01 00 13 00 20 00 06 C4 01 C1 00 01 00
13:13:34 Reading object 0.0.99.98.2.255, interface ProfileGeneric
00 01 00 20 00 13 00 0D C0 01 C1 00 07 00 00 63 62 02 FF 03 00
13:13:34
00 01 00 13 00 20 00 2A C4 01 C1 00 01 02 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00 60 0B 02 FF 0F 02 12 00 00
13:13:34 Reading object 0.0.99.98.3.255, interface ProfileGeneric
00 01 00 20 00 13 00 0D C0 01 C1 00 07 00 00 63 62 03 FF 03 00
13:13:34
13:13:34 Reading object 0.0.94.91.10.255, interface ProfileGeneric
00 01 00 20 00 13 00 0D C0 01 C1 00 07 00 00 5E 5B 0A FF 03 00
13:13:34
00 01 00 13 00 20 00 BA C4 01 C1 00 01 0A 02 04 12 00 01 09 06 00 00 60 01 00 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00 60 01 01 FF 0F 02 12 00 00 02 04 12 00 01 09 06 01 00 00 02 00 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00 5E 5B 09 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00 5E 5B 0B FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00 5E 5B 0C FF 0F 02 12 00 00 02 04 12 00 01 09 06 01 00 00 04 02 FF 0F 02 12 00 00 02 04 12 00 01 09 06 01 00 00 04 03 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00 60 01 04 FF 0F 02 12 00 00 02 04 12 00 01 09 06 01 00 00 03 00 FF 0F 02 12 00 00
13:13:34 Reading object 1.0.94.91.3.255, interface ProfileGeneric
00 01 00 20 00 13 00 0D C0 01 C1 00 07 01 00 5E 5B 03 FF 03 00
13:13:35
00 01 00 13 00 20 05 70 C4 01 C1 00 01 4D 02 04 12 00 03 09 06 01 00 1F 07 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 33 07 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 47 07 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 20 07 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 34 07 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 48 07 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 21 07 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 35 07 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 49 07 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 0D 07 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 0E 07 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 09 07 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 01 07 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 03 07 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 01 08 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 02 08 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 09 08 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 0A 08 00 FF 0F 03 12 00 00 02 04 12 00 01 09 06 00 00 60 07 00 FF 0F 00 12 00 00 02 04 12 00 03 09 06 00 00 5E 5B 08 FF 0F 03 12 00 00 02 04 12 00 01 09 06 00 00 5E 5B 00 FF 0F 00 12 00 00 02 04 12 00 01 09 06 00 00 00 01 00 FF 0F 00 12 00 00 02 04 12 00 01 09 06 00 00 60 02 00 FF 0F 00 12 00 00 02 04 12 00 03 09 06 00 00 00 01 02 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 24 07 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 38 07 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 4C 07 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 80 07 26 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 80 07 27 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 80 07 28 FF 0F 03 12 00 00 02 04 12 00 01 09 06 01 00 80 07 29 FF 0F 00 12 00 00 02 04 12 00 03 09 06 01 00 80 07 35 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 80 07 36 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 80 07 37 FF 0F 03 12 00 00 02 04 12 00 01 09 06 01 00 80 07 2D FF 0F 00 12 00 00 02 04 12 00 03 09 06 01 00 80 07 23 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 80 07 24 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 80 07 25 FF 0F 03 12 00 00 02 04 12 00 01 09 06 01 00 80 07 2E FF 0F 00 12 00 00 02 04 12 00 03 09 06 01 00 80 08 1C FF 0F 03 12 00 00 02 04 12 00 01 09 06 01 00 80 07 2B FF 0F 00 12 00 00 02 04 12 00 03 09 06 01 00 80 08 1D FF 0F 03 12 00 00 02 04 12 00 01 09 06 01 00 80 07 2C FF 0F 00 12 00 00 02 04 12 00 03 09 06 01 00 80 08 22 FF 0F 03 12 00 00 02 04 12 00 01 09 06 01 00 80 07 31 FF 0F 00 12 00 00 02 04 12 00 03 09 06 01 00 80 07 44 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 80 07 41 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 80 07 42 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 80 07 43 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 80 07 48 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 80 07 45 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 80 07 46 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 80 07 47 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 80 07 11 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 80 07 15 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 80 07 12 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 80 07 16 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 80 07 13 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 80 07 17 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 05 08 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 06 08 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 07 08 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 08 08 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 10 08 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 80 07 95 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 80 08 07 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 80 08 08 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 80 08 09 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 80 08 0A FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 80 08 0B FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 80 08 0C FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 80 08 0D FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 80 08 0E FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 80 08 BE FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 80 08 BF FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 80 08 C0 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 80 08 C1 FF 0F 03 12 00 00
13:13:35 Reading object 1.0.94.91.4.255, interface ProfileGeneric
00 01 00 20 00 13 00 0D C0 01 C1 00 07 01 00 5E 5B 04 FF 03 00
13:13:35 Get profile generic columns...
13:13:35
00 01 00 13 00 20 01 26 C4 01 C1 00 01 10 02 04 12 00 03 09 06 01 00 0E 1B 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 20 1B 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 34 1B 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 48 1B 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 01 1D 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 10 1D 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 02 1D 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 05 1D 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 06 1D 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 07 1D 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 08 1D 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 80 07 0E FF 0F 03 12 00 00 02 04 12 00 01 09 06 01 00 80 07 59 FF 0F 00 12 00 00 02 04 12 00 03 09 06 01 00 80 07 6E FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 09 1D 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 0A 1D 00 FF 0F 03 12 00 00
13:13:35 Reading object 1.0.94.91.5.255, interface ProfileGeneric
00 01 00 20 00 13 00 0D C0 01 C1 00 07 01 00 5E 5B 05 FF 03 00
13:13:35
00 01 00 13 00 20 00 DE C4 01 C1 00 01 0C 02 04 12 00 03 09 06 01 00 01 08 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 02 08 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 09 08 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 0A 08 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 5E 5B 01 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 5E 5B 02 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 05 08 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 06 08 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 07 08 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 08 08 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 10 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 80 07 95 FF 0F 02 12 00 00
13:13:35 Reading object 1.0.94.91.7.255, interface ProfileGeneric
00 01 00 20 00 13 00 0D C0 01 C1 00 07 01 00 5E 5B 07 FF 03 00
13:13:35
00 01 00 13 00 20 00 DE C4 01 C1 00 01 0C 02 04 12 00 01 09 06 00 00 60 0B 00 FF 0F 00 12 00 00 02 04 12 00 03 09 06 01 00 1F 07 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 33 07 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 47 07 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 20 07 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 34 07 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 48 07 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 21 07 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 35 07 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 49 07 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 01 08 00 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 00 02 08 00 FF 0F 03 12 00 00
13:13:36
13:13:36 Reading object 1.0.94.91.7.255, interface ProfileGeneric
13:13:36 Get profile generic columns...
13:13:36
13:13:36
13:13:48 Read object type ProfileGeneric index: 4
00 01 00 20 00 13 00 0D C0 01 C1 00 07 01 00 5E 5B 03 FF 04 00
13:13:49
00 01 00 13 00 20 00 09 C4 01 C1 00 06 00 00 00 00
13:13:49 Read object type ProfileGeneric index: 5
00 01 00 20 00 13 00 0D C0 01 C1 00 07 01 00 5E 5B 03 FF 05 00
13:13:49
00 01 00 13 00 20 00 06 C4 01 C1 00 16 04
13:13:49 Read object type ProfileGeneric index: 6
00 01 00 20 00 13 00 0D C0 01 C1 00 07 01 00 5E 5B 03 FF 06 00
13:13:49
00 01 00 13 00 20 00 16 C4 01 C1 00 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00
13:13:49 Reading profile generic data
00 01 00 20 00 13 00 40 C0 01 C1 00 07 01 00 5E 5B 03 FF 02 01 01 02 04 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 09 0C 07 E5 02 12 FF 00 00 00 FF 01 4A 00 09 0C 07 E5 02 13 FF 00 00 00 FF 01 4A 00 01 00
13:13:49
00 01 00 13 00 20 01 D6 C4 01 C1 00 01 01 02 4D 02 02 0F FD 16 21 02 02 0F FD 16 21 02 02 0F FD 16 21 02 02 0F FE 16 23 02 02 0F FE 16 23 02 02 0F FE 16 23 02 02 0F FD 16 FF 02 02 0F FD 16 FF 02 02 0F FD 16 FF 02 02 0F FD 16 FF 02 02 0F FE 16 2C 02 02 0F 00 16 1C 02 02 0F 00 16 1B 02 02 0F 00 16 1D 02 02 0F FF 16 1E 02 02 0F FF 16 1E 02 02 0F FF 16 1F 02 02 0F FF 16 1F 02 02 0F 00 16 FF 02 02 0F 00 16 06 02 02 0F 00 16 FF 02 02 0F 00 16 FF 02 02 0F 00 16 FF 02 02 0F 00 16 FF 02 02 0F 00 16 1B 02 02 0F 00 16 1B 02 02 0F 00 16 1B 02 02 0F 00 16 06 02 02 0F 00 16 06 02 02 0F 00 16 06 02 02 0F 00 16 FF 02 02 0F 00 16 06 02 02 0F 00 16 06 02 02 0F 00 16 06 02 02 0F 00 16 FF 02 02 0F 00 16 06 02 02 0F 00 16 06 02 02 0F 00 16 06 02 02 0F 00 16 FF 02 02 0F 00 16 06 02 02 0F 00 16 FF 02 02 0F 00 16 06 02 02 0F 00 16 FF 02 02 0F 00 16 06 02 02 0F 00 16 FF 02 02 0F FD 16 1F 02 02 0F FD 16 1E 02 02 0F FD 16 20 02 02 0F FD 16 20 02 02 0F FD 16 1F 02 02 0F FD 16 1E 02 02 0F FD 16 20 02 02 0F FD 16 20 02 02 0F FD 16 FF 02 02 0F FD 16 FF 02 02 0F FD 16 FF 02 02 0F FD 16 FF 02 02 0F FD 16 FF 02 02 0F FD 16 FF 02 02 0F FF 16 20 02 02 0F FF 16 20 02 02 0F FF 16 20 02 02 0F FF 16 20 02 02 0F FF 16 1E 02 02 0F FF 16 20 02 02 0F FF 16 20 02 02 0F FF 16 20 02 02 0F FF 16 20 02 02 0F FF 16 20 02 02 0F FF 16 20 02 02 0F FF 16 20 02 02 0F FF 16 20 02 02 0F FF 16 20 02 02 0F FF 16 20 02 02 0F FF 16 20 02 02 0F FF 16 20 02 02 0F FF 16 20
13:13:51 Read object type ProfileGeneric index: 7
00 01 00 20 00 13 00 0D C0 01 C1 00 07 01 00 5E 5B 03 FF 07 00
13:13:51
00 01 00 13 00 20 00 09 C4 01 C1 00 06 00 00 00 01
13:13:51 Read object type ProfileGeneric index: 8
00 01 00 20 00 13 00 0D C0 01 C1 00 07 01 00 5E 5B 03 FF 08 00
13:13:51
13:13:53 Read object type ProfileGeneric index: 4
00 01 00 20 00 13 00 0D C0 01 C1 00 07 01 00 5E 5B 04 FF 04 00
13:13:53
13:13:53 Read object type ProfileGeneric index: 5
00 01 00 20 00 13 00 0D C0 01 C1 00 07 01 00 5E 5B 04 FF 05 00
13:13:53
13:13:53 Read object type ProfileGeneric index: 6
00 01 00 20 00 13 00 0D C0 01 C1 00 07 01 00 5E 5B 04 FF 06 00
13:13:53
13:13:53 Reading profile generic data
00 01 00 20 00 13 00 40 C0 01 C1 00 07 01 00 5E 5B 04 FF 02 01 01 02 04 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 09 0C 07 E5 02 12 FF 00 00 00 FF 01 4A 00 09 0C 07 E5 02 13 FF 00 00 00 FF 01 4A 00 01 00
13:13:54
00 01 00 13 00 20 00 68 C4 01 C1 00 01 01 02 10 02 02 0F FE 16 2C 02 02 0F FD 16 23 02 02 0F FD 16 23 02 02 0F FD 16 23 02 02 0F FC 16 1E 02 02 0F FC 16 1E 02 02 0F FC 16 1E 02 02 0F FC 16 20 02 02 0F FC 16 20 02 02 0F FC 16 20 02 02 0F FC 16 20 02 02 0F FD 16 23 02 02 0F 00 16 FF 02 02 0F FC 16 20 02 02 0F FC 16 1F 02 02 0F FC 16 1F
13:13:54 Read object type ProfileGeneric index: 7
00 01 00 20 00 13 00 0D C0 01 C1 00 07 01 00 5E 5B 04 FF 07 00
13:13:54
13:13:54 Read object type ProfileGeneric index: 8
00 01 00 20 00 13 00 0D C0 01 C1 00 07 01 00 5E 5B 04 FF 08 00
13:13:54
13:13:57 Read object type ProfileGeneric index: 4
00 01 00 20 00 13 00 0D C0 01 C1 00 07 01 00 5E 5B 05 FF 04 00
13:13:57
13:13:57 Read object type ProfileGeneric index: 5
00 01 00 20 00 13 00 0D C0 01 C1 00 07 01 00 5E 5B 05 FF 05 00
13:13:57
13:13:57 Read object type ProfileGeneric index: 6
00 01 00 20 00 13 00 0D C0 01 C1 00 07 01 00 5E 5B 05 FF 06 00
13:13:57
13:13:57 Reading profile generic data
00 01 00 20 00 13 00 40 C0 01 C1 00 07 01 00 5E 5B 05 FF 02 01 01 02 04 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 09 0C 07 E5 02 12 FF 00 00 00 FF 01 4A 00 09 0C 07 E5 02 13 FF 00 00 00 FF 01 4A 00 01 00
13:13:59
00 01 00 13 00 20 00 50 C4 01 C1 00 01 01 02 0C 02 02 0F FF 16 1E 02 02 0F FF 16 1E 02 02 0F FF 16 1F 02 02 0F FF 16 1F 02 02 0F FF 16 20 02 02 0F FF 16 20 02 02 0F FF 16 20 02 02 0F FF 16 20 02 02 0F FF 16 20 02 02 0F FF 16 20 02 02 0F FF 16 1E 02 02 0F FF 16 20
13:13:59 Read object type ProfileGeneric index: 7
00 01 00 20 00 13 00 0D C0 01 C1 00 07 01 00 5E 5B 05 FF 07 00
13:13:59
13:13:59 Read object type ProfileGeneric index: 8
00 01 00 20 00 13 00 0D C0 01 C1 00 07 01 00 5E 5B 05 FF 08 00
13:13:59
13:14:02 Read object type ProfileGeneric index: 4
00 01 00 20 00 13 00 0D C0 01 C1 00 07 01 00 5E 5B 07 FF 04 00
13:14:02
13:14:02 Read object type ProfileGeneric index: 5
00 01 00 20 00 13 00 0D C0 01 C1 00 07 01 00 5E 5B 07 FF 05 00
13:14:02
13:14:02 Read object type ProfileGeneric index: 6
00 01 00 20 00 13 00 0D C0 01 C1 00 07 01 00 5E 5B 07 FF 06 00
13:14:02
13:14:02 Reading profile generic data
00 01 00 20 00 13 00 40 C0 01 C1 00 07 01 00 5E 5B 07 FF 02 01 01 02 04 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 09 0C 07 E5 02 12 FF 00 00 00 FF 01 4A 00 09 0C 07 E5 02 13 FF 00 00 00 FF 01 4A 00 01 00
13:14:02
00 01 00 13 00 20 00 50 C4 01 C1 00 01 01 02 0C 02 02 0F 00 16 FF 02 02 0F FD 16 21 02 02 0F FD 16 21 02 02 0F FD 16 21 02 02 0F FE 16 23 02 02 0F FE 16 23 02 02 0F FE 16 23 02 02 0F FE 16 FF 02 02 0F FE 16 FF 02 02 0F FE 16 FF 02 02 0F FF 16 1E 02 02 0F FF 16 1E
13:14:03 Read object type ProfileGeneric index: 7
00 01 00 20 00 13 00 0D C0 01 C1 00 07 01 00 5E 5B 07 FF 07 00
13:14:03
13:14:03 Read object type ProfileGeneric index: 8
00 01 00 20 00 13 00 0D C0 01 C1 00 07 01 00 5E 5B 07 FF 08 00
13:14:03
13:14:05 Read object type ProfileGeneric index: 4
13:14:05
13:14:05 Read object type ProfileGeneric index: 5
13:14:05
13:14:05 Read object type ProfileGeneric index: 6
13:14:05
13:14:05 Reading profile generic data
13:14:06
13:14:06 Read object type ProfileGeneric index: 7
13:14:06
13:14:06 Read object type ProfileGeneric index: 8
13:14:06
13:14:08 Read object type ProfileGeneric index: 4
13:14:08
13:14:08 Read object type ProfileGeneric index: 5
13:14:08
13:14:08 Read object type ProfileGeneric index: 6
13:14:08
13:14:08 Reading profile generic data
13:14:08
13:14:08 Read object type ProfileGeneric index: 7
13:14:08
13:14:08 Read object type ProfileGeneric index: 8
13:14:08
13:14:10 Read object type ProfileGeneric index: 4
13:14:10
13:14:10 Read object type ProfileGeneric index: 5
13:14:11
13:14:11 Read object type ProfileGeneric index: 6
13:14:11
13:14:11 Reading profile generic data
13:14:11
13:14:11 Read object type ProfileGeneric index: 7
13:14:11
13:14:11 Read object type ProfileGeneric index: 8
13:14:11
Thanks & Regards,
Pradson
