I'm trying to use the "-i" command line parameter to talk to a Landis+Gyr E650. In the code, it seems to correctly set the 300 bauds speed, but then doesn't seem to send the "/?!<CR><LF>" handshake like GuruxDLMSDirector does.
Could you confirm this is not supported yet?
Thank you so much for all the effort.
XmlClient client example doesn't implement Mode E support at the moment. We'll add it and release a new version next week.
