image transfer through gurux dlmsDirector failed when I applied Secured connections(authentication&encryption) while login.
After clicked on update button few seconds later "Unacceptable frame" error came
with out keys(means Security connections as NONE) it is working fine.
Please help me where is the problem.
Meter is replying to the wrong frame. I can't get any information from the pictures. Add the last frame that the meter sends as a string and I'll check what is wrong in the frame.
Unacceptableframe is coming
Thanks for Reply,
Please check the log.
15:26:56
<!--Decrypt data: C0 01 C1 00 12 00 00 2C 00 00 FF 05 00
<GetRequest>
<GetRequestNormal>
<AttributeDescriptor>
<!--ImageTransfer-->
<ClassId Value="0012" />
<!--0.0.44.0.0.255-->
<InstanceId Value="00002C0000FF" />
<AttributeId Value="05" />
</AttributeDescriptor>
</GetRequestNormal>
</GetRequest>
<glo_GetRequest Value="30000000BB60DF0B9C8F21ABA7DACA43C2A03A09A5CCFBD993373DD431AD" />
15:26:56
<!--Decrypt data: C4 01 C1 00 03 01
<GetResponse>
<GetResponseNormal>
<Result>
<Data>
<Boolean Value="true" />
</Data>
</Result>
</GetResponseNormal>
</GetResponse>
<glo_GetResponse Value="30000004C3F4750109DCBF628F13BAA5231DB142B7C7D8" />
15:26:56
<!--Decrypt data: C0 01 C1 00 12 00 00 2C 00 00 FF 02 00
<GetRequest>
<GetRequestNormal>
<AttributeId Value="02" />
</GetRequestNormal>
</GetRequest>
<glo_GetRequest Value="30000000BCD56BB03503FE559145D53B5606C50C77F2E51707C580AA9DAF" />
15:26:56
<!--Decrypt data: C4 01 C1 00 06 00 00 00 C0
<GetResponse>
<GetResponseNormal>
<Result>
<Data>
<UInt32 Value="000000C0" />
</Data>
</Result>
</GetResponse>
<glo_GetResponse Value="30000004C4376130C895A9BB91D921D50A14228AEF8260A58C68" />
15:26:56
<!--Decrypt data: C3 01 C1 00 12 00 00 2C 00 00 FF 01 01 02 02 09 10 52 4D 33 76 2E 34 2E 37 2E 30 30 31 20 2E 31 34 06 00 03 44 A6
<ActionRequest>
<ActionRequestNormal>
<MethodDescriptor>
<MethodId Value="01" />
</MethodDescriptor>
<MethodInvocationParameters>
<Structure Qty="02" >
<!--RM3v.4.7.001 .14-->
<OctetString Value="524D33762E342E372E303031202E3134" />
<UInt32 Value="000344A6" />
</Structure>
</MethodInvocationParameters>
</ActionRequestNormal>
</ActionRequest>
<glo_ActionRequest Value="30000000BDA63142C682B7D4C2655004F2A5523E32E9CDDB40D11792A6E7A28862F48C86969B92BC21C04D654E5118FF5A2FB8E6264850" />
15:26:56
<!--Decrypt data: C7 01 C1 00 00
<ActionResponse>
<ActionResponseNormal>
<Result Value="Success" />
</ActionResponseNormal>
</ActionResponse>
<glo_ActionResponse Value="30000004C54A6369AAB04CF54278D7E7F66B1F9FFFC3" />
15:26:56
<!--Decrypt data: C0 01 C1 00 12 00 00 2C 00 00 FF 06 00
<GetRequest>
<GetRequestNormal>
<AttributeId Value="06" />
</GetRequestNormal>
</GetRequest>
<glo_GetRequest Value="30000000BEB52CE5B46126B2E99556B1E45115BB5597D88CA097F3F2C749" />
15:26:56
<!--Decrypt data: C4 01 C1 00 16 01
<GetResponse>
<GetResponseNormal>
<Result>
<Data>
<Enum Value="01" />
</Data>
</Result>
</GetResponse>
<glo_GetResponse Value="30000004C6DC02579647699F0742B843DB3825DD0D49F4" />
15:26:57
<!--Decrypt data: C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 00 09 81 C0 4D 4F D4 52 63 5B 5E 4C 00 03 44 A6 FF FF FF FF F8 5F 00 20 09 74 03 00 89 74 03 00 87 74 03 00 85 74 03 00 85 74 03 00 85 74 03 00 85 74 03 00 85 74 03 00 85 74 03 00 85 74 03 00 B5 73 03 00 85 74 03 00 85 74 03 00 8B 74 03 00 75 74 03 00 41 81 02 00 4F 81 02 00 71 81 02 00 7F 81 02 00 F5 08 02 00 AD 72 03 00 CD 5C 03 00 3F 5E 03 00 49 5E 03 00 9B 5E 03 00 A5 5E 03 00 01 72 03 00 9D 57 03 00 8D 74 03 00 F5 D6 02 00 61 73 03 00 D5 94 02 00 95 C0 01 00 39 74 03 00 39 82 02 00 2D 73 03 00 6D D8 02 00 85 D8 02 00 A7 D8 02 00 BF D8 02 00 1D 65 01 00 ED 6E 03 00 71 70 03 00
<ActionRequest>
<MethodDescriptor>
<MethodId Value="02" />
</MethodDescriptor>
<UInt32 Value="00000000" />
<OctetString Value="4D4FD452635B5E4C000344A6FFFFFFFFF85F002009740300897403008774030085740300857403008574030085740300857403008574030085740300B573030085740300857403008B74030075740300418102004F810200718102007F810200F5080200AD720300CD5C03003F5E0300495E03009B5E0300A55E0300017203009D5703008D740300F5D6020061730300D594020095C0010039740300398202002D7303006DD8020085D80200A7D80200BFD802001D650100ED6E030071700300" />
</Structure>
</ActionRequest>
<glo_ActionRequest Value="30000000BF63D6AB601FCC738D1043D6A71C6AE37B9929E5534E67F1F8E4482653364CE8E541782ECD03AF4EEE39093AF02E4E7C539B58A6AC32DA35E70368B1C514A2279DCEAFC69F34D9684C88C73415A85E92DEEB877131FA17C0C6CA98E439E7390296B4473A6CBE530B806140E98BFD4CB88ADD86DF1FAA08AD866C822F50978EBDD66F25EB6F444CB93A5D41DAFFE53580E98D15447CE2D622F5E948434A1116AF41DB07E05CD17DB047322377D4DEB84C538451872000B71D4BCE5BD746DF7336D1393A73BA6A49702F82D10616CA0140B08081AECAB1365226315DD293EF0BBF208CB843" />
15:26:57
<UnacceptableFrame>
</UnacceptableFrame>
Thanks for this, but it doesn't help me. I need the RAW bytes without XML. Change Trace to Hex.
Thanks for your Reply, This issue is Resolved.
Hi Ashok,
Hi Ashok,
Thanks for the information.
