When the connection is established and the meter is read for the first time the association view is read. There is a lot of data transported between the client and the meter. You should save the association view and read only the objects what you need. It will save a lot of time.
Usually, TX+ is Y, TX- is Z, RX- is B and RX+ is A, but you need to check this from the Moxa and Itron documentation.
Hi, thanks you. I can read
Hi, thanks you. I can read the ITRON energy meter. But it is very slow to read and respond. Can i know why
Serial port communication channel is not so fast.
