You are receiving GatewayRequest and the HDLC frame is the supervisory frame. This is wrong and the client accepts it as a reply. Are you communicating directly with the meter or is there a gateway in the middle?
Yes I am just using a "Serial to Ethernet" Converter in the middle.
Meter:RS485 > Converter > IP:Port
The serial port of the converter is mapped to IP & Port, I am using "Serial over Ethernet" option in Gurux configuration.
It was working most of the time, but sometimes I have this behavior.
Still this issue I have with Gurux.AMI
Please can you consider ?
The value is stored in the DB as Empty value ' '
And it is almost repeated for 1 meter of 176, sometimes the problem shows in other meters but less often.
Your meter is sending EventNotificationReques where HDLC sequence ID is 3. We have improved this and the new version is released at the beginning of January.
