By kapil, 7 October, 2020 Forums Gurux DLMS for Android Hi , When I am reading the clock object in some meter I am getting the MM-DD-YY(07-10-20) format and in some meter DD-MM-YY (10-07-20). Hi, Hi, Are you using the Android version to read it? Date-time is format using environment settings. It's coming in the same format always from the meter. BR, Mikko yes I am using android yes I am using android version . mobile phone date time is on DD- MM-YY. In some meters this problem occurs Hi, Hi, Are you sure that the date-time is correct on the meter? Can you check that from the meter? BR, Mikko Hi , Hi , Yes, It is depends on the android system environment. Thanks for your reply, Hi, Hi, I'm glad that this is solved. The new version from DLMS Android was released yesterday where are a lot of new features. BR, Mikko Thanks sir Thanks sir Log in or register to post comments
Hi ,
Hi ,
Thanks sir
Thanks sir
