By tagmout, 25 September, 2020 Forums DLMSDirector Hi , When we can use the option MQTT in media ? BR , Hi, Hi, You can use MQTT with GXDLMSDirector. BR, Mikko I asked in which case , we I asked in which case , we can use the option MQTT ? Thank You in advance . Hi, Hi, We have few clients that are using MQTT when reading data from the meter. Most of the meters are not supporting this. There is usually a special network interface card when this is used. BR, Mikko Log in or register to post comments
