You can use example with Gurux. Try without authentication first.
Our clients are reading them using TCP/IP connection so I can't say for sure but
if the meter doesn't reply change the Start protocol from DLMS to IEC.
i try with these parameters in the attached picture , but no work
below , the logs :
12:00:08 Initializing serial connection.
12:00:09 Send SNRM request.
7E A0 07 03 21 93 0F 01 7E
12:00:14 Data send failed. Try to resend 1/3
12:00:19 Data send failed. Try to resend 2/3
12:00:24 Failed to receive reply from the device in given time.
12:00:24 Disconnect request
12:00:24 Send Disconnect request.
7E A0 07 03 21 53 03 C7 7E
12:00:29 Data send failed. Try to resend 1/3
12:00:34 Data send failed. Try to resend 2/3
12:00:39 Failed to receive reply from the device in given time.
à GXDLMSDirector.GXDLMSDevice.InitializeConnection()
à GXDLMSDirector.MainForm.Connect(Object sender, GXAsyncWork work, Object[] parameters)
If there is a logo, then you can read it using Gurux products. Our clients are reading Sanxing meters using TCP/IP connection. If you want to use Low authentication client address is 32 (0x20).
Our clients are reading Sanxing SX meters. If your meters are supporting DLMS there should be no reason why you can't.
there is no sanxing in the
there is no sanxing in the manufacturer option , which one i have to use ?
and i use IEC or DLMS in start protocol ?
Thanks a lot .
We use this one below with
We use this one below with the optical cable .
http://www.sanxingelectric.com/prodeta.php?id=5bmy5ra4ezEzMH10aGlzX2lzX…
below , the logs :
Select Advanced and try to change the baud rate. The easiest is if you ask correct settings from the meter manufacturer.
Can You please check with us
Can You please check with us if this meter supports DLMS ,
Thank You a lot of ,
That link doesn't tell anything. There is only basic info. You need to ask this from the meter vendor.
Dlms logo is printed on the
Dlms logo is printed on the meter so it supports dlms of course
