I am used Sumeru verde energy meter(ERP300P).
I am used Gurux.DLMS.Python to read the value of energy meter.
My energy meter is high level password and its password is 2222222222222222.
I am run the command python main.py -S /dev/ttyUSB0 -a High -P 2222222222222222 -c 48.
Its given a errors...
gurux_dlms version: 1.0.93
gurux_net version: 1.0.17
gurux_serial version: 1.0.15
Authentication: Authentication.HIGH
ClientAddress: 0x30
Standard: Standard.DLMS
Profile Generic 0.0.94.91.10.255Columns:
0.0.96.1.0.255 Ch. 0 Device ID 1, manufacturing number | 0.0.96.1.2.255 Ch. 0 Device ID #3 | 0.0.96.1.1.255 Ch. 0 Device ID #2 | 1.0.0.2.0.255 Ch. 0 Active firmware identifier | 0.0.94.91.9.255 Ch. 0 Identifiers for India | 0.0.94.91.11.255 Ch. 0 Identifiers for India | 0.0.94.91.12.255 Ch. 0 Identifiers for India | 0.0.96.1.4.255 Ch. 0 Device ID #5
Profile Generic 0.0.99.98.1.255Columns:
0.0.1.0.0.255 Ch. 0 Clock object #1 | 0.0.96.11.1.255 | 1.0.94.91.14.255 | 1.0.12.7.0.255 Ch. 0 Voltage: any phase Inst. value | 1.0.13.7.0.255 Ch. 0 Sum Li Power factor Inst. value | 1.0.1.8.0.255 Ch. 0 Sum Li Active power+ (QI+QIV) Time integral 1 Rate 0 (0 is total)
Profile Generic 0.0.99.98.2.255Columns:
0.0.1.0.0.255 Ch. 0 Clock object #1 | 0.0.96.11.2.255
Profile Generic 0.0.99.98.3.255Columns:
0.0.1.0.0.255 Ch. 0 Clock object #1 | 0.0.96.11.3.255
Profile Generic 0.0.99.98.4.255Columns:
0.0.1.0.0.255 Ch. 0 Clock object #1 | 0.0.96.11.4.255 | 1.0.94.91.14.255 | 1.0.12.7.0.255 Ch. 0 Voltage: any phase Inst. value | 1.0.13.7.0.255 Ch. 0 Sum Li Power factor Inst. value | 1.0.1.8.0.255 Ch. 0 Sum Li Active power+ (QI+QIV) Time integral 1 Rate 0 (0 is total)
Profile Generic 0.0.99.98.5.255Columns:
0.0.1.0.0.255 Ch. 0 Clock object #1 | 0.0.96.11.5.255
Profile Generic 0.0.99.98.6.255Columns:
0.0.1.0.0.255 Ch. 0 Clock object #1 | 0.0.96.11.6.255
Profile Generic 1.0.94.91.0.255Columns:
0.0.1.0.0.255 Ch. 0 Clock object #1 | 1.0.12.7.0.255 Ch. 0 Voltage: any phase Inst. value | 1.0.11.7.0.255 Ch. 0 Current: any phase Inst. value | 1.0.91.7.0.255 Ch. 0 Lo Current (neutral) Inst. value | 1.0.13.7.0.255 Ch. 0 Sum Li Power factor Inst. value | 1.0.14.7.0.255 Ch. 0 Supply frequency Inst. value | 1.0.9.7.0.255 Ch. 0 Sum Li Apparent power+ (QI+QIV) Inst. value | 1.0.1.7.0.255 Ch. 0 Sum Li Active power+ (QI+QIV) Inst. value | 1.0.1.8.0.255 Ch. 0 Sum Li Active power+ (QI+QIV) Time integral 1 Rate 0 (0 is total) | 1.0.9.8.0.255 Ch. 0 Sum Li Apparent power+ (QI+QIV) Time integral 1 Rate 0 (0 is total) | 1.0.1.6.0.255 Ch. 0 Sum Li Active power+ (QI+QIV) Max. 1 Rate 0 (0 is total) | 1.0.1.6.0.255 Ch. 0 Sum Li Active power+ (QI+QIV) Max. 1 Rate 0 (0 is total) | 1.0.9.6.0.255 Ch. 0 Sum Li Apparent power+ (QI+QIV) Max. 1 Rate 0 (0 is total) | 1.0.9.6.0.255 Ch. 0 Sum Li Apparent power+ (QI+QIV) Max. 1 Rate 0 (0 is total) | 0.0.94.91.14.255 Ch. 0 Identifiers for India | 0.0.94.91.0.255 Ch. 0 Identifiers for India | 0.0.0.1.0.255 Ch. 0 Billing period counter (1) #255 | 0.0.96.2.0.255 Ch. 0 No. of configuration program changes | 1.0.2.8.0.255 Ch. 0 Sum Li Active power- (QII+QIII) Time integral 1 Rate 0 (0 is total) | 1.0.10.8.0.255 Ch. 0 Sum Li Apparent power- (QII+QIII) Time integral 1 Rate 0 (0 is total) | 0.0.96.3.10.255 Ch. 0 Disconnect control | 0.0.17.0.0.255 Ch. 0 Limiter #1
Profile Generic 1.0.94.91.3.255Columns:
1.0.12.7.0.255 Ch. 0 Voltage: any phase Inst. value | 1.0.11.7.0.255 Ch. 0 Current: any phase Inst. value | 1.0.91.7.0.255 Ch. 0 Lo Current (neutral) Inst. value | 1.0.13.7.0.255 Ch. 0 Sum Li Power factor Inst. value | 1.0.14.7.0.255 Ch. 0 Supply frequency Inst. value | 1.0.9.7.0.255 Ch. 0 Sum Li Apparent power+ (QI+QIV) Inst. value | 1.0.1.7.0.255 Ch. 0 Sum Li Active power+ (QI+QIV) Inst. value | 1.0.1.8.0.255 Ch. 0 Sum Li Active power+ (QI+QIV) Time integral 1 Rate 0 (0 is total) | 1.0.9.8.0.255 Ch. 0 Sum Li Apparent power+ (QI+QIV) Time integral 1 Rate 0 (0 is total) | 1.0.1.6.0.255 Ch. 0 Sum Li Active power+ (QI+QIV) Max. 1 Rate 0 (0 is total) | 1.0.9.6.0.255 Ch. 0 Sum Li Apparent power+ (QI+QIV) Max. 1 Rate 0 (0 is total) | 0.0.94.91.14.255 Ch. 0 Identifiers for India | 1.0.2.8.0.255 Ch. 0 Sum Li Active power- (QII+QIII) Time integral 1 Rate 0 (0 is total) | 1.0.10.8.0.255 Ch. 0 Sum Li Apparent power- (QII+QIII) Time integral 1 Rate 0 (0 is total) | 0.0.17.0.0.255 Ch. 0 Limiter #1
Profile Generic 1.0.94.91.4.255Columns:
1.0.12.27.0.255 | 1.0.1.29.0.255 | 1.0.9.29.0.255 | 1.0.2.29.0.255 | 1.0.10.29.0.255
Profile Generic 1.0.94.91.5.255Columns:
1.0.2.8.0.255 Ch. 0 Sum Li Active power- (QII+QIII) Time integral 1 Rate 0 (0 is total) | 1.0.10.8.0.255 Ch. 0 Sum Li Apparent power- (QII+QIII) Time integral 1 Rate 0 (0 is total) | 1.0.1.8.0.255 Ch. 0 Sum Li Active power+ (QI+QIV) Time integral 1 Rate 0 (0 is total) | 1.0.9.8.0.255 Ch. 0 Sum Li Apparent power+ (QI+QIV) Time integral 1 Rate 0 (0 is total)
Profile Generic 1.0.94.91.6.255Columns:
1.0.13.0.0.255 | 1.0.1.8.0.255 Ch. 0 Sum Li Active power+ (QI+QIV) Time integral 1 Rate 0 (0 is total) | 1.0.1.8.1.255 | 1.0.1.8.2.255 | 1.0.1.8.3.255 | 1.0.1.8.4.255 | 1.0.9.8.0.255 Ch. 0 Sum Li Apparent power+ (QI+QIV) Time integral 1 Rate 0 (0 is total) | 1.0.9.8.1.255 | 1.0.9.8.2.255 | 1.0.9.8.3.255 | 1.0.9.8.4.255 | 1.0.1.6.0.255 Ch. 0 Sum Li Active power+ (QI+QIV) Max. 1 Rate 0 (0 is total) | 1.0.9.6.0.255 Ch. 0 Sum Li Apparent power+ (QI+QIV) Max. 1 Rate 0 (0 is total) | 0.0.94.91.13.255 | 1.0.2.8.0.255 Ch. 0 Sum Li Active power- (QII+QIII) Time integral 1 Rate 0 (0 is total) | 1.0.10.8.0.255 Ch. 0 Sum Li Apparent power- (QII+QIII) Time integral 1 Rate 0 (0 is total)
Profile Generic 1.0.94.91.7.255Columns:
Profile Generic 1.0.98.1.0.255Columns:
0.0.0.1.2.255 | 1.0.13.0.0.255 | 1.0.1.8.0.255 Ch. 0 Sum Li Active power+ (QI+QIV) Time integral 1 Rate 0 (0 is total) | 1.0.1.8.1.255 | 1.0.1.8.2.255 | 1.0.1.8.3.255 | 1.0.1.8.4.255 | 1.0.9.8.0.255 Ch. 0 Sum Li Apparent power+ (QI+QIV) Time integral 1 Rate 0 (0 is total) | 1.0.9.8.1.255 | 1.0.9.8.2.255 | 1.0.9.8.3.255 | 1.0.9.8.4.255 | 1.0.1.6.0.255 Ch. 0 Sum Li Active power+ (QI+QIV) Max. 1 Rate 0 (0 is total) | 1.0.1.6.0.255 Ch. 0 Sum Li Active power+ (QI+QIV) Max. 1 Rate 0 (0 is total) | 1.0.9.6.0.255 Ch. 0 Sum Li Apparent power+ (QI+QIV) Max. 1 Rate 0 (0 is total) | 1.0.9.6.0.255 Ch. 0 Sum Li Apparent power+ (QI+QIV) Max. 1 Rate 0 (0 is total) | 0.0.94.91.13.255 | 1.0.2.8.0.255 Ch. 0 Sum Li Active power- (QII+QIII) Time integral 1 Rate 0 (0 is total) | 1.0.10.8.0.255 Ch. 0 Sum Li Apparent power- (QII+QIII) Time integral 1 Rate 0 (0 is total)
Profile Generic 1.0.99.1.0.255Columns:
0.0.1.0.0.255 Ch. 0 Clock object #1 | 1.0.12.27.0.255 | 1.0.1.29.0.255 | 1.0.9.29.0.255 | 1.0.2.29.0.255 | 1.0.10.29.0.255
Profile Generic 1.0.99.2.0.255Columns:
0.0.1.0.0.255 Ch. 0 Clock object #1 | 1.0.2.8.0.255 Ch. 0 Sum Li Active power- (QII+QIII) Time integral 1 Rate 0 (0 is total) | 1.0.10.8.0.255 Ch. 0 Sum Li Apparent power- (QII+QIII) Time integral 1 Rate 0 (0 is total) | 1.0.1.8.0.255 Ch. 0 Sum Li Active power+ (QI+QIV) Time integral 1 Rate 0 (0 is total) | 1.0.9.8.0.255 Ch. 0 Sum Li Apparent power+ (QI+QIV) Time integral 1 Rate 0 (0 is total)
-------- Reading 1 0.0.0.1.0.255 Ch. 0 Billing period counter (1) #255
Index: 1 Value: 30 2E 30 2E 30 2E 31 2E 30 2E 32 35 35
Index: 2 Value: 3
-------- Reading 1 0.0.0.1.1.255 Ch. 0 No. of available billing periods (1)
Index: 1 Value: 30 2E 30 2E 30 2E 31 2E 31 2E 32 35 35
Index: 2 Value: 3
-------- Reading 8 0.0.1.0.0.255 Ch. 0 Clock object #1
Index: 1 Value: 30 2E 30 2E 31 2E 30 2E 30 2E 32 35 35
Index: 2 Value: 09/06/20 09:29:00:000000
Index: 3 Value: 330
Index: 4 Value: 0
Attribute5 is not readable.
Attribute6 is not readable.
Attribute7 is not readable.
Attribute8 is not readable.
Index: 9 Value: 1
-------- Reading 20 0.0.13.0.0.255 Ch. 0 Activity calendar #1
Index: 1 Value: 30 2E 30 2E 31 33 2E 30 2E 30 2E 32 35 35
Index: 2 Value: 2017
Index: 3 Value: SN01 01/01/20 00:00:00:000000
Index: 4 Value: 57 6B 30 31
Index: 5 Value: 49 00:00:00 0.0.10.0.100.255 10:00:00 0.0.10.0.100.255 12:00:00 0.0.10.0.100.255 15:00:00 0.0.10.0.100.255
Index: 6 Value: 2017
Index: 7 Value: SN01 01/01/20 00:00:00:000000
Index: 8 Value: 57 6B 30 31
Index: 9 Value: 49 00:00:00 0.0.10.0.100.255 10:00:00 0.0.10.0.100.255 12:00:00 0.0.10.0.100.255 15:00:00 0.0.10.0.100.255
Index: 10 Value: /00 00:00:00:000000
-------- Reading 22 0.0.15.0.0.255 Ch. 0 End of billing period
Index: 1 Value: 30 2E 30 2E 31 35 2E 30 2E 30 2E 32 35 35
Index: 2 Value: 30 2E 30 2E 31 30 2E 30 2E 31 2E 32 35 35, 110
Index: 3 Value: 1
Index: 4 Value: 01/01 00:00, 02/01 00:00, 03/01 00:00, 04/01 00:00, 05/01 00:00, 06/01 00:00, 07/01 00:00, 08/01 00:00, 09/01 00:00, 10/01 00:00, 11/01 00:00, 12/01 00:00
-------- Reading 22 0.0.15.0.2.255 Ch. 0 Image activation
Index: 1 Value: 30 2E 30 2E 31 35 2E 30 2E 32 2E 32 35 35
Index: 2 Value: 30 2E 30 2E 31 30 2E 30 2E 31 30 37 2E 32 35 35, 111
Index: 3 Value: 1
Index: 4 Value: 00:00
-------- Reading 22 0.0.15.0.4.255 Ch. 0 Push
Index: 1 Value: 30 2E 30 2E 31 35 2E 30 2E 34 2E 32 35 35
Index: 2 Value: 30 2E 30 2E 31 30 2E 30 2E 31 30 38 2E 32 35 35, 112
Index: 3 Value: 1
Index: 4 Value: 00:00:00:000000
-------- Reading 71 0.0.17.0.0.255 Ch. 0 Limiter #1
Index: 1 Value: 30 2E 30 2E 31 37 2E 30 2E 30 2E 32 35 35
Index: 2 Value: 1.0.1.7.0.255 Ch. 0 Sum Li Active power+ (QI+QIV) Inst. value
Index: 3 Value: 15120
Index: 4 Value: 15120
Index: 5 Value: 13000
Index: 6 Value: 60
Index: 7 Value: 60
Index: 8 Value: 116 01/01/01 01:00:00:000000 1800
Index: 9 Value: 120
Index: 10 Value: False
Index: 11 Value: 0.0.10.0.106.255 11, 0.0.10.0.106.255 12
-------- Reading 41 0.0.25.0.0.255 Ch. 0 TCP-UDP setup
Index: 1 Value: 30 2E 30 2E 32 35 2E 30 2E 30 2E 32 35 35
Index: 2 Value: 0
Index: 3 Value: 30 2E 30 2E 30 2E 30 2E 30 2E 30
Index: 4 Value: 0
Index: 5 Value: 0
Index: 6 Value: 0
-------- Reading 48 0.0.25.7.0.255 Ch. 0 IPv6 setup
Index: 1 Value: 30 2E 30 2E 32 35 2E 37 2E 30 2E 32 35 35
Attribute2 is not readable.
Index: 3 Value: AddressConfigMode.AUTO
Error! Index: 4 inet_ntop() argument 2 must be string or read-only buffer, not bytearray
File "/home/pi/dlmsMeterCode/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 426, in getReadOut
val = self.read(it, pos)
File "/home/pi/dlmsMeterCode/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 327, in read
return self.client.updateValue(item, attributeIndex, reply.value)
File "/home/pi/.local/lib/python2.7/site-packages/gurux_dlms/GXDLMSClient.py", line 776, in updateValue
target.setValue(self.settings, e)
File "/home/pi/.local/lib/python2.7/site-packages/gurux_dlms/objects/GXDLMSIp6Setup.py", line 247, in setValue
self.unicastIPAddress.append(socket.inet_ntop(socket.AF_INET6, it))
TypeError: inet_ntop() argument 2 must be string or read-only buffer, not bytearray
Error! Index: 5 inet_ntop() argument 2 must be string or read-only buffer, not bytearray
File "/home/pi/.local/lib/python2.7/site-packages/gurux_dlms/objects/GXDLMSIp6Setup.py", line 254, in setValue
self.multicastIPAddress.append(socket.inet_ntop(socket.AF_INET6, it))
Error! Index: 6 inet_ntop() argument 2 must be string or read-only buffer, not bytearray
File "/home/pi/.local/lib/python2.7/site-packages/gurux_dlms/objects/GXDLMSIp6Setup.py", line 261, in setValue
self.gatewayIPAddress.append(socket.inet_ntop(socket.AF_INET6, it))
Error! Index: 7 inet_ntop() argument 2 must be string or read-only buffer, not bytearray
File "/home/pi/.local/lib/python2.7/site-packages/gurux_dlms/objects/GXDLMSIp6Setup.py", line 266, in setValue
self.primaryDNSAddress = socket.inet_ntop(socket.AF_INET6, e.value)
Error! Index: 8 inet_ntop() argument 2 must be string or read-only buffer, not bytearray
File "/home/pi/.local/lib/python2.7/site-packages/gurux_dlms/objects/GXDLMSIp6Setup.py", line 273, in setValue
self.secondaryDNSAddress = socket.inet_ntop(socket.AF_INET6, e.value)
Attribute9 is not readable.
Attribute10 is not readable.
-------- Reading 15 0.0.40.0.1.255 Ch. 0 Association #1
Index: 1 Value: 30 2E 30 2E 34 30 2E 30 2E 31 2E 32 35 35
Index: 2 Value:
Index: 3 Value: 16, 1
Index: 4 Value: 0 0 0 5 8 1 1
Index: 5 Value: 524288 512 512 6 0
Index: 8 Value: 0
-------- Reading 15 0.0.40.0.2.255 Ch. 0 Association #2
Index: 1 Value: 30 2E 30 2E 34 30 2E 30 2E 32 2E 32 35 35
Attribute3 is not readable.
Attribute4 is not readable.
-------- Reading 15 0.0.40.0.3.255 Ch. 0 Association #3
Index: 1 Value: 30 2E 30 2E 34 30 2E 30 2E 33 2E 32 35 35
-------- Reading 15 0.0.40.0.4.255 Ch. 0 Association #4
Index: 1 Value: 30 2E 30 2E 34 30 2E 30 2E 34 2E 32 35 35
-------- Reading 15 0.0.40.0.5.255 Ch. 0 Association #5
Index: 1 Value: 30 2E 30 2E 34 30 2E 30 2E 35 2E 32 35 35
-------- Reading 1 0.0.42.0.0.255 Ch. 0 COSEM Logical device name
Index: 1 Value: 30 2E 30 2E 34 32 2E 30 2E 30 2E 32 35 35
Index: 2 Value: AGT001-1117-0020
-------- Reading 1 0.0.94.91.0.255 Ch. 0 Identifiers for India
Index: 1 Value: 30 2E 30 2E 39 34 2E 39 31 2E 30 2E 32 35 35
-------- Reading 1 0.0.94.91.9.255 Ch. 0 Identifiers for India
Index: 1 Value: 30 2E 30 2E 39 34 2E 39 31 2E 39 2E 32 35 35
-------- Reading 1 0.0.94.91.11.255 Ch. 0 Identifiers for India
Index: 1 Value: 30 2E 30 2E 39 34 2E 39 31 2E 31 31 2E 32 35 35
-------- Reading 1 0.0.94.91.12.255 Ch. 0 Identifiers for India
Index: 1 Value: 30 2E 30 2E 39 34 2E 39 31 2E 31 32 2E 32 35 35
-------- Reading 3 0.0.94.91.14.255 Ch. 0 Identifiers for India
Index: 1 Value: 30 2E 30 2E 39 34 2E 39 31 2E 31 34 2E 32 35 35
-------- Reading 1 0.0.94.91.18.255 Ch. 0 Identifiers for India
Index: 1 Value: 30 2E 30 2E 39 34 2E 39 31 2E 31 38 2E 32 35 35
-------- Reading 1 0.0.96.1.0.255 Ch. 0 Device ID 1, manufacturing number
Index: 1 Value: 30 2E 30 2E 39 36 2E 31 2E 30 2E 32 35 35
Index: 2 Value: SMR01-1117-0020
-------- Reading 1 0.0.96.1.1.255 Ch. 0 Device ID #2
Index: 1 Value: 30 2E 30 2E 39 36 2E 31 2E 31 2E 32 35 35
-------- Reading 1 0.0.96.1.2.255 Ch. 0 Device ID #3
Index: 1 Value: 30 2E 30 2E 39 36 2E 31 2E 32 2E 32 35 35
-------- Reading 1 0.0.96.1.4.255 Ch. 0 Device ID #5
Index: 1 Value: 30 2E 30 2E 39 36 2E 31 2E 34 2E 32 35 35
-------- Reading 1 0.0.96.2.0.255 Ch. 0 No. of configuration program changes
Index: 1 Value: 30 2E 30 2E 39 36 2E 32 2E 30 2E 32 35 35
-------- Reading 70 0.0.96.3.10.255 Ch. 0 Disconnect control
Index: 1 Value: 30 2E 30 2E 39 36 2E 33 2E 31 30 2E 32 35 35
-------- Reading 4 0.0.96.11.1.255 Ch. 0 Event code #2
Index: 1 Value: 30 2E 30 2E 39 36 2E 31 31 2E 31 2E 32 35 35
-------- Reading 4 0.0.96.11.2.255 Ch. 0 Event code #3
Index: 1 Value: 30 2E 30 2E 39 36 2E 31 31 2E 32 2E 32 35 35
-------- Reading 4 0.0.96.11.3.255 Ch. 0 Event code #4
Index: 1 Value: 30 2E 30 2E 39 36 2E 31 31 2E 33 2E 32 35 35
-------- Reading 4 0.0.96.11.4.255 Ch. 0 Event code #5
Index: 1 Value: 30 2E 30 2E 39 36 2E 31 31 2E 34 2E 32 35 35
-------- Reading 4 0.0.96.11.5.255 Ch. 0 Event code #6
Index: 1 Value: 30 2E 30 2E 39 36 2E 31 31 2E 35 2E 32 35 35
-------- Reading 4 0.0.96.11.6.255 Ch. 0 Event code #7
Index: 1 Value: 30 2E 30 2E 39 36 2E 31 31 2E 36 2E 32 35 35
-------- Reading 1 1.0.0.2.0.255 Ch. 0 Active firmware identifier
Index: 1 Value: 31 2E 30 2E 30 2E 32 2E 30 2E 32 35 35
-------- Reading 1 1.0.0.8.0.255 Ch. 0 Measurement period 1, for averaging scheme 1
Index: 1 Value: 31 2E 30 2E 30 2E 38 2E 30 2E 32 35 35
-------- Reading 1 1.0.0.8.4.255 Ch. 0 Recording interval 1, for load profile
Index: 1 Value: 31 2E 30 2E 30 2E 38 2E 34 2E 32 35 35
-------- Reading 1 1.0.0.8.5.255 Ch. 0 Recording interval 2, for load profile
Index: 1 Value: 31 2E 30 2E 30 2E 38 2E 35 2E 32 35 35
-------- Reading 4 1.0.1.6.0.255 Ch. 0 Sum Li Active power+ (QI+QIV) Max. 1 Rate 0 (0 is total)
Index: 1 Value: 31 2E 30 2E 31 2E 36 2E 30 2E 32 35 35
-------- Reading 3 1.0.1.7.0.255 Ch. 0 Sum Li Active power+ (QI+QIV) Inst. value
Index: 1 Value: 31 2E 30 2E 31 2E 37 2E 30 2E 32 35 35
-------- Reading 3 1.0.1.8.0.255 Ch. 0 Sum Li Active power+ (QI+QIV) Time integral 1 Rate 0 (0 is total)
Index: 1 Value: 31 2E 30 2E 31 2E 38 2E 30 2E 32 35 35
-------- Reading 3 1.0.2.8.0.255 Ch. 0 Sum Li Active power- (QII+QIII) Time integral 1 Rate 0 (0 is total)
Index: 1 Value: 31 2E 30 2E 32 2E 38 2E 30 2E 32 35 35
-------- Reading 3 1.0.3.7.0.255 Ch. 0 Sum Li Reactive power+ (QI+QII) Inst. value
Index: 1 Value: 31 2E 30 2E 33 2E 37 2E 30 2E 32 35 35
-------- Reading 4 1.0.9.6.0.255 Ch. 0 Sum Li Apparent power+ (QI+QIV) Max. 1 Rate 0 (0 is total)
Index: 1 Value: 31 2E 30 2E 39 2E 36 2E 30 2E 32 35 35
-------- Reading 3 1.0.9.7.0.255 Ch. 0 Sum Li Apparent power+ (QI+QIV) Inst. value
Index: 1 Value: 31 2E 30 2E 39 2E 37 2E 30 2E 32 35 35
-------- Reading 3 1.0.9.8.0.255 Ch. 0 Sum Li Apparent power+ (QI+QIV) Time integral 1 Rate 0 (0 is total)
Index: 1 Value: 31 2E 30 2E 39 2E 38 2E 30 2E 32 35 35
-------- Reading 3 1.0.10.8.0.255 Ch. 0 Sum Li Apparent power- (QII+QIII) Time integral 1 Rate 0 (0 is total)
Index: 1 Value: 31 2E 30 2E 31 30 2E 38 2E 30 2E 32 35 35
-------- Reading 3 1.0.11.7.0.255 Ch. 0 Current: any phase Inst. value
Index: 1 Value: 31 2E 30 2E 31 31 2E 37 2E 30 2E 32 35 35
-------- Reading 3 1.0.12.7.0.255 Ch. 0 Voltage: any phase Inst. value
Index: 1 Value: 31 2E 30 2E 31 32 2E 37 2E 30 2E 32 35 35
-------- Reading 3 1.0.13.7.0.255 Ch. 0 Sum Li Power factor Inst. value
Index: 1 Value: 31 2E 30 2E 31 33 2E 37 2E 30 2E 32 35 35
-------- Reading 3 1.0.14.7.0.255 Ch. 0 Supply frequency Inst. value
Index: 1 Value: 31 2E 30 2E 31 34 2E 37 2E 30 2E 32 35 35
-------- Reading 3 1.0.91.7.0.255 Ch. 0 Lo Current (neutral) Inst. value
Index: 1 Value: 31 2E 30 2E 39 31 2E 37 2E 30 2E 32 35 35
-------- Reading 7 0.0.94.91.10.255 Ch. 0 Identifiers for India
Entries: 1/1
Error! Failed to read first row: Access Error : Device reports a inconsistent Class or object.
Error! Failed to read last day: Access Error : Device reports a inconsistent Class or object.
-------- Reading 7 0.0.99.98.1.255 Ch. 0 Event log #2
Entries: 0/20
-------- Reading 7 0.0.99.98.2.255 Ch. 0 Event log #3
Entries: 0/20
-------- Reading 7 0.0.99.98.3.255 Ch. 0 Event log #4
Entries: 0/10
-------- Reading 7 0.0.99.98.4.255 Ch. 0 Event log #5
Entries: 0/10
-------- Reading 7 0.0.99.98.5.255 Ch. 0 Event log #6
Entries: 0/1
-------- Reading 7 0.0.99.98.6.255 Ch. 0 Event log #7
Entries: 0/10
-------- Reading 7 1.0.94.91.0.255 Ch. 0 Identifiers for India
Entries: 1/1
-------- Reading 7 1.0.94.91.3.255 Ch. 0 Identifiers for India
Entries: 1/1
-------- Reading 7 1.0.94.91.4.255 Ch. 0 Identifiers for India
Entries: 1/1
-------- Reading 7 1.0.94.91.5.255 Ch. 0 Identifiers for India
Entries: 1/1
-------- Reading 7 1.0.94.91.6.255 Ch. 0 Identifiers for India
Entries: 1/1
-------- Reading 7 1.0.94.91.7.255 Ch. 0 Identifiers for India
Entries: 1/1
-------- Reading 7 1.0.98.1.0.255 Ch. 0 Data of billing period Scheme 1 #1 Unspecified number of most recent billing periods
Entries: 4/13
07 E4 07 01 03 00 00 00 00 80 00 00 |
0 |
0 |
0 |
0 |
0 |
0 |
0 |
0 |
0 |
0 |
0 |
0 |
/00 00:00:00:000000 |
0 |
16352 |
0 |
0 |
-------- Reading 7 1.0.99.1.0.255 Ch. 0 Load profile with recording period 1 #1
Entries: 1680/1680
-------- Reading 7 1.0.99.2.0.255 Ch. 0 Load profile with recording period 2 #1
Entries: 35/35
09/06/20 00:00:00:000000 |
0 |
0 |
0 |
0 |
What am I doing wrong? Please suggest me.
Your meter is returning IP addresses in the wrong format. Can you read IPv6 setup 0.0.25.7.0.255 attribute index 4 and add trace here. I can check what the meter is returning.
Add only that one reply.
