Dlms-Cosem On GPRS For Gas Meter
2 posts / 0 new
Last post
Caner Dinçer
I need to add dlms/cosem structure on our gas metering module so which will run on GPRS(udp) network.
As far as i understand on this platform, our module must push messages in scheduled time and must act like a client.
At this point, is it enough using of dlms client source code on Gurux Git? I'm a little confused about this integration so could you help me?
Best Regards
Kurumi's picture
You need to download Gurux.DLMS.Push.Listener.Example.
https://github.com/Gurux/Gurux.DLMS.Net/tree/master/Gurux.DLMS.Push.List...
It will listen to push messages and convert them to XML.
If you are using ciphered connection you must set correct authentication and block cipher keys.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
