1) i donot want the client because i am not reading any meter data.
2) in the server code, there is already server.initialize() again what do i need for server intilization???
The server code is if you want to implement DLMS meter. If you are not reading any data what you want to do? Server.initialize function is used when you create DLMS meter.
You need to initialize the server. In your reply, you said that you have connected the meter?
If you want to read the meter you need to make a client.
Hi Nishitha,
Hi Nishitha,
