hi,
i am using intellij and connected my meter through serial port, when i run the .jar file in the target folder, i am getting error as getParameter method is not there, so i wanted to debug the code, how do i hardcode the function getParameter: it has 2 parameters-(args,settings), how do i give -S COM6 there?, in .jar normally we give filename.jar -S COM6
If you want to read your meter you need to use the client.example. It will make a connection to the meter and reads all the objects from it. The server is if you want to implement own meter or proxy.
You should give parameters as normal. Something like:
java -jar gurux.dlms.server.example.java-0.0.1-SNAPSHOT.jar -S COM6
gurux.dlms.server.example can directly communicate to meter with only this -S COM6 port parameter
can you explain procedure
