Step by step to implment gurux dlms java server
4 posts / 0 new
Last post
hridendra
please guide me on how to create a setup for the DLMS as the server.
Kurumi's picture
Download gurux.dlms.server.example.java from GitHub and read this:
https://www.gurux.fi/Gurux.DLMS.Server
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
hridendra
I make run the code (gurux.dlms.server.example.java) and it is connected through socket and received when i push data from other side socket, But when I connected the Meter it shows connected but did not received any information while connected. The method on connected (onClientConnected) is called. So tell me how we can fetch the meter data information while on connect.
I am not able to get data from meter after the meter connected.
Hridendra
Kurumi's picture
Hi Hridendra,
If you want to read data from the meter, you need to implement a client, not a server.
I believe this might help you.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
