Its me again. I have a meter, that pushes a decrypted message every second. I can view it manually by using the Translator tool in Director by inserting the message and the block cipher key. Now i also got it to work with python, using your library and the classes „GXDLMSTranslator“, „TranslatorOutputType“ and „GXByteBuffer“.
However, i only have an ESP8266 near the Meter. That can not run Python. And i could not find the above mentioned Classes in your Ansi C library. Do you have an idea how i could get the translator running on ESP8266?
Alternatively, i use ioBroker as my SmartHome Server, which uses JavaScript. If you have a library for that, that would also be possible, however I would prefear to translate it on ESP8266.
Ok, i understand the memory issue. Is micropython more efficient with the memory? And if you coult try that, that would be awesome. Let me know when you have results!
Actually I don't know is this possible. This is something that people are asking and it would help a lot if we can make this work. Implementing reading with ANSI C is taking a lot more time.
Let's see is this possible. It might be that there is not enough memory.
Not yet. We are releasing a new version from ANSI C. MicroPython test is started right after this is released. I hope that tests are successfully ending this week.
Hi Christoph,
Hi Christoph,
We are not planning to add GXDLMSTranslator support for ANSI C for a short period.
The reason for this is the memory or lack of it.
We don't have library for Javascript at the moment.
But, we have a few ESP8266 microcontrollers and MicroPython looks interesting.
We can give it a try after two weeks. Let's see what happened.
Christoph
have you already tried it?
Br,
Christoph
Hi Christoph,
Hi Christoph,
