The fastest way to go is if you use our open source libraries to parse this. DLMS is not easy protocol.
In your example there is a DataNotification message inside of General Block Transfer message, but structure of GBT is wrong. Ask you meter manufacturer to fix it.
Content of the DataNotification message looks like this: http://www.gurux.fi/GuruxDLMSTranslator?pdu=0F0000001100020801080204120…
I put some of the my date now as part in your webtranslator:
Does this make any sense for you?
<Structure Qty="04" >
<UInt16 Value="0028" />
<!--0.8.25.9.0.255-->
<OctetString Value="0008190900FF" />
<Int8 Value="02" />
<UInt16 Value="0000" />
</Structure>
My EVU doesn't give any information about 0.8.25.9.0.255, they give us ID's like 1-0:32.7.0;2.
Hi Mikko
I'm still a little bit confused of my decrypted structure, why they put the same octetString twice once with Int8 Value 02 and once with Int8 Value 01?
Hi Max,
Hi Max,
<Int8 Value="02" />
</Structure>
R,
Max
The content of the data can be anything in data notification messages. Content depends on how the meter is configured.
I believe that OBIS code is the same. Only the presentation format is different.
Thank's
R,
Max
Hi Mikko
Hi Mikko
<Int8 Value="02" />
</Structure>
<Int8 Value="01" />
</Structure>
<UInt16 Value="0001" />
<!--0.0.96.1.0.255-->
<OctetString Value="0000600100FF" />
<Int8 Value="02" />
</Structure>
For what "Int8 Value" stand for?
Where can i read something about the structure.
Tanks in advance,
Max
Hi Max,
Hi Max,
Int8 is attribute index number. You read #1 and #2 from the object 0.8.25.9.0.255 and #2 from the object 0.0.96.1.0.255.
There is Ch. 7 Push setup object in data. It will describe what kind of data meter is sending.
