By Bhaumik, 27 February, 2020 Forums Gurux.DLMS Hi Mikko, We are doing testing using the MQTT interface. In that can we identify from the response that for which object this response received from the meter? I have checked in response there is no OBIS code available, So how we can identify the response and parse it accordingly? Can you please check to provide an update? Thanks Hi, Hi, MQTT sends plain DLMS PDU. There is no OBIS code in the reply packet. Reply depends on what you have tried to read from the meter. BR, Mikko Log in or register to post comments
