I have just started to program gurux.dlms in vb.net to read data from a eletric meter and I find difficulties, please help me get started! Thank you
NB: Good mastery of VB. NET
The best way to get started is if you download GXDLMSDirector and try to read your meter with it.
Then you can read your meter using the command line app if your parameters are correct. The example reads all the data from the meter and its idea is show what kind of data you can get from the meter.
Hi Elmir,
Hi Elmir,
