Client verifies invoke ID of received message.
Project:
gurux.dlms.cpp
Meters are now communicating more often using UDP connection. Messages are sometimes received as duplicate and this is causing problems. To handle this problem invoke ID of received message is verified. Note! All the meters are not supporting this. For this reason this must enable separably using GXClient.setAutoIncreaseInvokeID -method or using -I parameter in client example.
Status:
Closed (fixed)
Priority:
Normal
Category:
Support request
Component:
Code
Reporter:
Administrator
Created:
Fri, 02/21/2020 - 11:11
Updated:
Tue, 03/10/2020 - 12:55
Comments
Administrator's picture
Status: Active » Closed (fixed)
