By vakilian_TFC, 13 February, 2020 Forums DLMSDirector I have lots of parameters that i want to set in meter with serial port in C#. I have Class Name. Data. Class ID. Attribute ID. OBIS. Data Type. how can i do this??? Hi, Hi, You should check client example: https://github.com/Gurux/Gurux.DLMS.Net/tree/master/Gurux.DLMS.Client.E… It reads all the objects from the meter. There is a write-method that you can use to write value to the meter. BR, Mikko Log in or register to post comments
