I’m a student at a University and I was picked by this electricity company to find a way for them to communicate with the landis gyr cu-l52 lte module remotely via sim card data, it’s my first time working with this hardware and software, if anyone can, please kindly assist me
You can use GXDLMSDirector to read data from your meter. Download it and select Landis+Gyr for the manufacturer. Then set the correct IP address and start reading your meters.
Please I would be grateful to
Please I would be grateful to know how to configure cu-XE and CU-L52 communications modules using MAP 120
Make sure that you are using static IP addresses with the SIM card. The meter must start the communication if you are using a dynamic IP address.
There are so many settings that must be correct or your communication fails. I propose you contact your meter vendor and ask for the correct settings.
