I am using l&T ER300p meter. Its gives dlms data through RS232.
Connection between rj11 to DB9 as given link https://www.pinterest.fr/pin/461056080577439131/
When I am run this command.
python main.py -S /dev/ttyUSB0
Its gives an error.....
ClientAddress: 0x10
RX: 23:21:32
File "main.py", line 80, in main
reader.readAll()
File "/home/pi/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 423, in readAll
self.initializeConnection()
File "/home/pi/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 235, in initializeConnection
File "/home/pi/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 91, in readDLMSPacket
File "/home/pi/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 142, in readDLMSPacket2
raise e
TimeoutException: Failed to receive reply from the device in given time.
Can you read the meter with GXDLMSDirector? Select "Indian Standard" as a manufacturer.
If you can't check the cables.
bro, has this worked for you.
bro, has this worked for you. is the pinout accurate?
