By hurani, 10 November, 2019 Forums Gurux DLMS for Android Dear sir, May you add support for Iskra Meters Manufacturer in android app? Thank you in advance Hi, Hi, You can read Iskraemero meters with an Android app. Select IskraEmeco from the list of the manufacturers and connect them to the meter. If you have problems, try to connect first with GXDLMSDirector. BR, Mikko but its not in the spinner but its not in the spinner list!, Maybe they are wrong? HI, HI, Thanks for your help to solve this problem. Adding android:usesCleartextTraffic="true" solved the problem with Adnroid 9 and 10. BR, Mikko Log in or register to post comments
HI,
HI,
