  3. How To Delete System Title From Get/set Frame
How to delete System Title from get/set frame
By SgmUsr , 3 October, 2019
Hi all,
I'm using an italian standard meter and our meters don't need system title during get/set request:
(example:
7E A0 36 02 21 03 32 6C C0 E6 E6 00 DB 08 00 00 00 00 00 00 00 00 1E 30 80 00 00 55 0E 89 E1 E4 0C A5 EB BB 00 5C AF D9 A5 F3 B8 B1 E1 7D AF E0 23 37 B9 85 10 71 2C 7E ,
08 00 00 00 00 00 00 00 00 is my system title (08 is the lenght) and if I delete this and set 00 as substitute, I can decrypt this frame correctly.)
There is a method to not add system title?
7 years 1 month ago
If you set Standard to Italian system title is ignored.
In GXDLMSDirector you can set it on the meter's advanced tab.
GXDLMSSecureClient cl = new GXDLMSSecureClient();
cl.Standard = Standard.Italy;
SgmUsr
7 years 1 month ago
Thank you very much!
Now It's work.
SgmUsr
7 years 1 month ago
Hi Mr Mikko,
Hi Mr Mikko,
with this change I have another problem:
when I arrive at this point (inside ReadDlmsPacket() method)
//Loop until whole COSEM packet is received.
while (!clientSecured.GetData(p.Reply, reply, new GXReplyData())){ ...}
It always return reply.Error = 4, but I don't understand why, though settings are the same.
7 years 1 month ago
Because the system title is not coming from the meter you need to set manually.
In GXDLMSDirector select "Pre-established Application Associations" and set the system title of the meter.
