integerToHex wrongly converting negative integers
Project:
Gurux.DLMS.Python
integerToHex method of _GXCommon.py is wrongly converting negative integers to hex. For instance, -4 should be converted to FC, however it is converting it to X4. This is happening due to str_ = hex(value)[2:] line, as hex(-4) is '-0x4'.
Status:
Closed (fixed)
Priority:
Normal
Category:
Bug report
Component:
Code
Reporter:
zmiguel
Created:
Mon, 06/17/2019 - 23:22
Updated:
Tue, 03/03/2020 - 20:46
Comments
Kurumi's picture
This is verified and you are right. hex -method is Python standard method:
https://docs.python.org/3/library/functions.html#hex
We make own implementation from this. We'll update a new version on next week.
You can find a working example here:
https://gist.github.com/i96751414/b1ed2aef2cb9f602d03c305e22cb6e13
It takes into account negative numbers.
Also, just noticed that method integerString might be wrong for negative numbers. Please have a look at the implementation in the above gist.
Administrator's picture
Status: Active » Closed (fixed)
