Thanks for your reply, I have seen the Links which you are mentioned above.And in Github which code is belongs to meter? My meter communicates via RS232 for that any codes available?
I'm very new to this protocol and tried blue and yellow books too but unable to get the core points.
is there any documents like Application note or documents with data frame format,so that I can understand what is actually happening.
I'm using Arm cortex controller in my Energy meter.Now I have Modbus communication and I need to integrate DLMS server protocol for optical communication.I have checked with the open source codes and unable to identify the right one for my case so kindly tell me, which github code will be helpful me?
I believe that you want to use ANSI C.
Check example from GitHub:
https://github.com/gurux/guruxdlms.c
Then read http://www.gurux.fi/Gurux.DLMS.Server
Martin.
Blue book describes all the interfaces. You communicate with your meter using those interfaces. DLMS PDU is split to HDLC or WRAPPER frames.
Martin.
Hi Martin,
Hi Martin,
You need to create DLMS server. You should check this one:
Check GuruxDLMSSimpleServerExample.
