Can i get DLMS Meter Suite
6 posts / 0 new
Last post
rahul.singh@rad...
Can we get complete DLMS Suit to read DLMS Meter over TCP/IP from server and its parser to generate CDF file in java
Kurumi's picture
You can get it from here:
https://github.com/gurux/gurux.dlms.java
Use gurux.dlms.client.example.java as a template. It can read all the values from the meter.
You need to generate CDF file from the read values.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
rahul.singh@rad...
hi ,
is using serial port for communication . can't we use TCp/IP?
Kurumi's picture
Example supports both. Serial port and TCP/IP.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
rahul.singh@rad...
Can i get paid solution also
Can i get paid solution also to read all indian standard DLMS Meter ?
Kurumi's picture
You can read all DLMS meters. We can help you to make AMI system if needed. Send an email to me.
You'll find my address info from here:
http://www.gurux.fi/AboutUs
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
