By DARCARPER, 9 January, 2019 Forums Gurux DLMS for Java Hi I have a Raspberry, want to install Gurux but don't understand how to do it. you can help me? Thanks Gurux for Raspberry Hi, GXDLMSDirector is not work with Raspberry PI at the moment. What programming language you want to use? BR, Mikko I'm trying with python. I can I'm trying with python. I can send messages through an optical probe, but the meter does not answer. I guess it will be because the initial message is not correct. I have also tried to install GXDLMSDirector in Java, but it is impossible Gurux for Raspberry Hi, The best way is if you can install java to the Raspberry PI and get gurux.dlms.client.example.java from Github. BR, Mikko Log in or register to post comments
Gurux for Raspberry
Gurux for Raspberry
