sorry for this question but I'm new in dlms.
I could read DataRegisters with your support (thank you) it is easy: Console.WriteLine(reader.Read(new GXDLMSRegister("1.1.1.8.0.255"), 2));
But if I need pervious period data, previous month data (1.8.0*1 , 1.8.0*2.. in IEC)?
I found i have to use GXDLMSProfileGeneric object (am I right?)
I read lot of document and this forum examples, but unfortunatelly I couldn't find a simple example for reading previous period data for energy registers. example 1.8.0 Positive active energy previous month not .255. How can I read it?
GXDLMSProfileGeneric pg = new GXDLMSProfileGeneric("1.1.99.1.0.255");
//Set capture period to 60 second.
pg.From = DateTimeOffset.Now.AddDays(-1);
pg.To = DateTimeOffset.Now;
var res = reader.ReadRowsByRange(pg, DateTime.Now.AddDays(-1),DateTime.Now);
with this code I could read a byte array collection. Converting that datas to real values etc..
There is any example for reading ProfileGeneric Data ( previous periods?, load profile datas... etc.)
As I expecting. The manufacturer uses negative values for attributes. Attributes start from 1.
Can you ask from manufacturer what is the meaning of negative values and why they are using them?
A simple example for reading GXDLMSProfileGeneric ?
You can do it like this:
//Read capture objects.
reader.read(pg, 3);
reader.ReadRowsByRange(pg, DateTime.Now.AddDays(-1), DateTime.Now);
You can get data from pg.Buffer.
Thank you Mikko,
Thank you Mikko,
Formatting that buffer data, there are any method in Gurux?
or am I read some documentation?
So, in this situation; I dont know what means byte0 what means byte 1 etc..
If you have read the capture objects you can see actual values from the pg.Buffer.
That is not in byte array.
I got " Invalid attribute Index " excepiton.
may I send all log data email to you?
RX: 2:10:55 PM 7E A1 88 25 21 FC CF DB E6 E7 00 C4 02 C1 01 00 00 00 05 00 82 01 70 02 08 09 0C 07 E2 0B 10 05 0B 0F 00 FF 80 00 00 12 00 00 06 00 00 01 00 0F 01 06 00 00 4B 5E 06 00 00 00 00 06 00 00 00 35 06 00 00 08 D8 02 08 09 0C 07 E2 0B 10 05 0B 1E 00 FF 80 00 00 12 00 00 06 00 00 01 00 0F 01 06 00 00 4B 5F 06 00 00 00 00 06 00 00 00 35 06 00 00 08 D8 02 08 09 0C 07 E2 0B 10 05 0B 2D 00 FF 80 00 00 12 00 00 06 00 00 01 00 0F 01 06 00 00 4B 60 06 00 00 00 00 06 00 00 00 35 06 00 00 08 D9 02 08 09 0C 07 E2 0B 10 05 0C 00 00 FF 80 00 00 12 00 00 06 00 00 01 00 0F 01 06 00 00 4B 62 06 00 00 00 00 06 00 00 00 35 06 00 00 08 DA 02 08 09 0C 07 E2 0B 10 05 0C 0F 00 FF 80 00 00 12 00 00 06 00 00 01 00 0F 01 06 00 00 4B 63 06 00 00 00 00 06 00 00 00 35 06 00 00 08 DB 02 08 09 0C 07 E2 0B 10 05 0C 1E 00 FF 80 00 00 12 00 00 06 00 00 01 00 0F 01 06 00 00 4B 64 06 00 00 00 00 06 00 00 00 35 06 00 00 08 DC 02 08 09 0C 07 E2 0B 10 05 0C 2D 00 FF 80 00 00 12 00 00 06 00 00 01 00 0F 01 06 00 00 4B 66 06 00 00 00 00 06 00 00 00 35 06 00 00 08 DC 02 08 09 0C 07 E2 0B 10 05 0D 00 00 FF 80 00 00 12 00 00 06 00 00 01 00 0F 01 06 00 00 4B 67 06 00 00 00 00 06 00 00 00 35 06 00 00 08 DD D7 80 7E
Unhandled Exception: System.ArgumentOutOfRangeException: Specified argument was out of the range of valid values.
Parameter name: Invalid attribute Index.
at Gurux.DLMS.ManufacturerSettings.GXAttributeCollection.Find(Int32 index)
at Gurux.DLMS.Objects.GXDLMSObject.GetAttribute(Int32 index, GXAttributeCollection attributes)
at Gurux.DLMS.Objects.GXDLMSObject.GetUIDataType(Int32 index)
at Gurux.DLMS.Objects.GXDLMSProfileGeneric.SetBuffer(GXDLMSSettings settings, ValueEventArgs e)
at Gurux.DLMS.Objects.GXDLMSProfileGeneric.Gurux.DLMS.Objects.IGXDLMSBase.SetValue(GXDLMSSettings settings, ValueEventArgs e)
at Gurux.DLMS.GXDLMSClient.UpdateValue(GXDLMSObject target, Int32 attributeIndex, Object value, List`1 columns)
at Gurux.DLMS.GXDLMSClient.UpdateValue(GXDLMSObject target, Int32 attributeIndex, Object value)
at GuruxTest.GXDLMSReader.ReadRowsByRange(GXDLMSProfileGeneric it, DateTime start, DateTime end) in C:\Repos\Gurux\Gurux\GuruxTest\GuruxDLMSReader.cs:line 884
Send log to me by email. Read also capture objects. It seems that your meter is configured wrong
and attribute index is less than zero. I'll check.
I sent email for full log.
I sent email for full log. thank you Mikko;
Hello Mikko,
Hello Mikko,
I found abnormal data in the captured Objects :
Other 6 objects are ok.
But object number 1 and 2 has wrong AttributeIndex value,
{1.1.99.1.0.255 Ch. 1 Load profile with recording period 1 #1}
AttributeIndex -1 int
AttributeIndex -2 int
Negative values are not on the standard.
Asked to the manifacturer
Asked to the manifacturer Mikko, I'll inform you when I learn something.
While waiting their answer, I wonder, can I ignore that wrong formatted objects easly.
But i guess it can break buffered data meanings, I'm not sure..
Open GXDLMSProfileGeneric file.
Sinf Setbuffer meth0d and change:
//Actaris SL 7000 and ACE 6000 returns 0.
if (index2 != 0)
to
if (index2 > 0)
Nice hack,
Nice hack,
I got Capturedobject values clearly with your support.
For the previous month value (for billing), May I set this range to this month first day 00:00 - 00:15 ? isn't it?
You can get data as you want to. Just give start and end time.
