We are using Gurux DLMS .NET library to communicate with Landis+Gyr meter. A manufacturer application requires to input 4 last digits of the meter serial number +1000 as a server address to establish communication with the meter.
These (last 4 digits + 1000) are 4470 and are translated as server address bytes in a frame sent to the meter as 0x000244ED.
To connect with a meter with Gurux library we need to set the following properties of GXDLMSSecureClient class instance:
- ServerAddress=23820
- ServerAddressSize=4
This translates into the same server address bytes 0x000244ED.
Can you please tell us how can we configure GXDLMSSecureClient instance with last 4 last digits of the meter serial so it translates a server address in a frame to bytes 0x000244ED ?
Server address GXDLMSSecureClient
GXDLMSClient.GetServerAddress(Server address 4470);
