I am working on Genus 3-phase meter with DLMS Protocol.
I can check data using a Common Meter Reading Instrument, even I can check data using GXDLMSDirector via optical port.
I suppose to collect the meter data via Serial/Optical port using Microcontroller and send it further.
I am using 16-bit microcontroller with 16KB SRAM & 128KB ROM and a IDE with C++ AVR Compiler.
My queries are:
1. Is my controller is sufficient to handle the GuruX DLMS Stack?
2. As I am using only Serial Port for communication, can I skip, ignore or comment out the code related to other communication media. If YES, which files can be excluded from the project?
3. I am getting STL related error while compiling. Please suggest the STL link that includes all the files required to successful compilation.
4. Kindly suggest the essential defines to begin...
GuruX DLMS Protocol Porting on Microcontroller
I believe that you need to use our ANSI C stack. It's not open source.
Send an email to me if you are interested in it.
Thanks for Replay Mikko...
Yes... I am interested.
Please Share email address.
Thanks & Regards...
