The DLMS Library seems very promising, but unfortunately, I only work on .NET Core, and have tried to compile for the .NET Core system, but to no avail. Is there support for the .NET Core framework?
Can anyone point me in the right direction?
@kurumi?
We have made few changes so you can compile Gurux.DLMS for .Net Core.
We are checking how we can release that version also to nuget.org. Because projects are made with VS 2015 it is causing some problems. We have to update projects to use VS 2017 project file.
.NET Core 2.0 support for DLMS.NET?
Hi Ruhan,
.NET core code
Hi, thank you for your reply, when can I expect to get this code/solution?
Changes are made. We try to release it at this week.
New version was released on Friday where is support for.Net Core.
