Using obis code 1.0.0.0.3.255 in gurux, I'm not able to change the default value 256 to other values.
Gurux is showing read/write access for that data object, but still i am not able to write a value.
Same have been done using meter's manufacturer software. Please help in this issue.
meter used: Microstar P2000-T
Hola Vinayak, ¿puedes ayudarme a conectarme al medidor de energía Microstar? Necesito la configuración para conectarme al medidor, el modelo del medidor es P2000-D
changing hdlc address
What is the object type?
Object type is Data
Make sure that OBIS code and object type are correct.
Can you show bytes what manufacturer software is sending?
The write message is enough.
Hi Vinayak, can you help me
Hi Vinayak, can you help me making connection to the Microstar Energy meter? I need the settings to connect to the meter, meter model is P2000-D
