Is anyone of you aware of an implementation to access a DLMS/COSEM server via a COSEM Access Service (CAS) defined in "IEC TS 62056-9-1 Part 9-1: Communication profile using web-services to access a DLMS/COSEM server via a COSEM Access Service (CAS)" ?
Gurux java and C# libraries are supporting XML schema, but other functionality is not implemented at the moment. We'll implement if our clients want it.
COSEM Access Service (CAS) implementation
