i need to read obis codes from two cewe prometers r, i created a new cewe manufacturer using landys&gyr manufacturer information, changing only the manufacturer id, i can connect to the cewe but i can get only two obis codes, date and manufacturer name... Someone know where i can find obis codes list for cewe prometer r?
The next week i will go back to the company where cewe prometers are installed and i will have one week to make it working...
I have a problem also with an ISKRA MT860, i will explain the problem in a new thread.
Thank you in advance for help, and i wish to everyone a happy new year!
thank you! I will try next week your hint, but if i use low level of authentication i must set a password, in the cewe manual there is no passwords, also with cewe config software i can read values from counter but i don't use any password when i connecting to it
Some meters are not show all registers on association view. It's sad because then client do not know what kind of registers there are. We do not have this meter so if you can read your meter with other software and get trace from sent and received bytes we can add those registers to template.
You can find email address here: http://www.gurux.fi/AboutUs
CEWE meters
I believe that you need to use higher authentication level. I believe that if you use Low authentication level you can see more interfaces.
CEWE meters
Hi Mikko
Thank you
Best regards
Denis.
CEWE meters
Hi Denis,
CEWE meters
Ok i will try to get trace of sent and received bytes, i will update you
Thank you!
Best regards
Denis.
