I tried using the settings from the Landis+Gyr meter but it doesn't seem to respond once switching from IEC mode.
Here is the log file sample.
10:20:02 Initializing serial connection.
10:20:02 HDLC sending:/?!<CR><LF>
10:20:02 HDLC received: /CWI5\2<CR><LF>
10:20:02 BaudRate is : 9600
10:20:02 Moving to mode E.
06 32 35 32 0D 0A
10:20:04 Send SNRM request.
7E A0 08 02 01 23 93 8E E1 7E
10:20:09 Failed to receive reply from the device in given time.
We sent a inquery from your meter settings to the manufacturer two weeks ago.
They have not answered anything.
Is there DLMS label on the cover of the meter?
OBIS codes file for CEWE Promoter 100 meter
We have not read CEWE Promoter meter before.
This is a big problem because every meter manufacturer is using different settings.
You can try to select Landis+Gyr in GXDLMSDirector and then read your meter.
If you do not receive reply, change starting protocol from IEC to DLMS.
Let me know what happened.
06 32 35 32 0D 0A
