Hi sir,
We are using android library. How we can communicate meter using single OBIS command?. Is there any code or reference? Please help.
Ex: logical name: 0.0.1.0.0.255
output data: 13/07/2021 16:24:10
HI sir,
We are using Larsen & Turbo DLMS 3-phase meter. Also tell me how to get result using
1) Data object ( i.e Exp: 0.0.42.0.0.255),
2) Register object ( i.e Exp: 1.0.32.7.0.255 (Voltage))
3) ProfileGenerica object ( i.e Exp: 1.0.99.1.0.255 (Load profile..1))
Any code how to get data. Please help me.
Hi sir,
We don't want all the objects come from the meter only few i.e 7 to 8 object values. That's it. How can we get the values only manually given objects. Is there any specific way?
Please help me.
You need to establish the connection to the meter before you can read anything, so you can't do this with a single command.
You can skip reading the association view and read clock object like this:
//Open the connection...
GXDLMSClock clock = new GXDLMSClock("0.0.1.0.0.255");
read(clock, 2);
//Close the connection...
Hi sir,
Hi sir,
Thank you for your reply. We are doing open and close connection correctly. But this
read(clock); // Here accepting only one parameter not 2 param's.
Unable receive data if we pass only one parameter( i.e clock object). Is there any other code or any
modification is required?
Please help me.
Check this:
https://github.com/Gurux/Gurux.DLMS.Android/blob/036e1a1de18f45e312e40e…
Hi sir,
Hi sir,
Open and close connection working fine. We checked this code
readObject(clock,2);
Getting message "Failed to receive reply from the device in given time".
Is there any other way or any modification is required?
Please help me.
Do you call initializeConnection method? Opening the connection is not that you just open the serial port connectio.
Virabhadrappa which meter
Virabhadrappa which meter your using and can you tell me Meter Details
HI sir,
HI sir,
Virabhadrappa can you me your
Virabhadrappa can you me your email because i am also working on same LNT 3 phase android
Check the android example. It will read the association view and read all the objects from the meter.
Hi sir,
Hi sir,
Please help me.
You need to add those objects like this:
GXDLMSData data = new GXDLMSData("Logical name");
readObject(data,2);
Find refresh and add objects that you want to read to there.
