I Cannot set Token into the Meter. Can you please suggest how can i Set token into the meter. I can get and set clock information. But while i tried to set Token using TokenGateway class and using Method() from GSDLMSClient it. what should i do can you please suggest? what should be the correct approach?
I have answerd for your question here:
http://www.gurux.fi/node/13266
